2010 Prius brake bleed after m/c replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Mach3, Jan 14, 2025.
  1. Mach3
    Mach3 New Member
    Ohio
    I have a 2010 Prius. I replaced the master cylinder/actuator and accumulator/pump with new Toyota parts. I have a Topdon Artidiag900 Lite scan tool. I am trying to bleed the brakes and do the Linear Valve offset learn. When I try to do the bleed procedure, the scan tool says "Failed to communicate with module". I can connect and read live data, also i can read and erase DTC's, so it is communicating. I have bled the system, but I cannot get to the linear valve offset. Any ideas what to try next?
  2. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,514
    Durham NC
    Seems quite a few have this problem I don't know whether it's a scanner issue or something else I mean at this point I would be pulling out my CF19 toughbook with TIS on it and see if the Toyota software will do it some don't have that luxury I've had communication problems before.
  3. Mendel Leisk
    42,305
    Consider phoning a dealership service department, see what they’d charge? And if they’d be willing to, in light of DIY replacement? Assuming it’s drivable, at least to them and back.
