2010 Prius - brake booster - Sell or Keep
Discussion in 'Gen 3 Prius Main Forum' started by mkprius, Aug 14, 2023.
  1. mhdriver
    mhdriver Member
    162
    61
    florida
    Oh, only a SLIGHT advantage over me, who has trouble discerning one end of a wrench from the other.
    Mendel Leisk and ASRDogman like this.
  2. Dlewisa
    Dlewisa Junior Member
    US
    I tend to agree about the EGR. But I think it is also in combination with the PCV system. The exhaust is sooty and gross and the oil in the manifold catches that soot and clogs the ports. Then the cooler clogs and everything is out of whack and not performing consistently across all cylinders. From what I've heard Toyota never recommended cleaning or replacing cooler, just replacing the valve and had some kind of software update. I think it was CarCareNut on youtube that did a video about it and said he'd get grief from people about not cleaning the cooler. And he should get grief about it, because it's short sighted. If we imagine that the EGR valve is a mouth that talks or sings when open then we can see that it doesn't matter if the mouth works properly when there's no air supply!
  3. Mendel Leisk
    42,323
    Toyota could be considered a “hostile witness” on this subject? They’ve designed and implemented a system that reliably clogs, with an engine that reliably blows head gaskets. All of this by 150~200k miles. There is a warranty extension for the EGR system, but its language, and its omissions, suggest a protracted huddle with their lawyers.
    FWIW, fourth gen has a similar EGR system, with some very fundamental revisions (which were even touted in a Toyota press release); it barely soots up, even when inspected with 300k plus miles (Tampa Hybrids verified), and the only head gasket failures reported here so far, were likely due coolant leaks in the exhaust heat recovery system.
  4. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    I don't think he advised against having a clean EGR cooler, and he also did not discourage DIYers from cleaning it out. For a paying customer that comes to a Toyota tech, however, the only way to ensure it is in perfect working condition is to replace it with a new one. Cleaning takes more time and has variable results, and shop time is precious.
    ASRDogman likes this.
  5. ASRDogman
    ASRDogman Senior Member
    8,056
    4,084
    He told why they don't clean parts. If he cleaned a part, that a DIYer would, and there is a problem,
    he will have to repair it for no additional cost to the customer. Plus the customer will not be happy it wasn't
    fixed the first time.
    Since the cooler doesn't have any moving parts, and is stainless steel, cleaning it wouldn't be a problem.
  6. Mendel Leisk
    42,323
    That Toyota dropped us in it, and the dealerships refuse to clean parts that eminently cleanable, what a SNAFU.
  7. Abarnabe
    Abarnabe Active Member
    172
    102
    Netherlands
    Since Toyota will not share any statistics, it would be interesting to collect some info to forecast imminent failures or things that could speed up the failure.
    I think 3 factors should be looked into:
    mileage
    age
    temperature
    I assume freezing temperatures like -20 C would expose any weakness of the elastic membrane or rubber seal behind the nitrogen chamber.
  8. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    I have similar situation, plan to swap the intake manifolds with the cleaned one and also the EGR, EGR elbow pipe. I probably will not mess around with pain in the nuts EGR cooler. Just blast it off with air compressor. Is your car burning engine oil? I think if the previous owner do 5k oil change interval or use a good full synthetic oil, the odd is much less.
