2010 Prius cabin positive Wire location
Discussion in 'Gen 3 Prius Technical Discussion' started by MHLikhon, Nov 25, 2018.
  1. MHLikhon
    MHLikhon Junior Member
    GB
    Business Ed. Plus
    can angone please reply which wire or fuse gives power after locking or turning off the car but won't give power after unlock or start the car?
    Thanks
    52,853
    don't think there is such a thing. you'll probably have to find a live wire and customize
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Or revise your expectations.
    Sometimes "plan B" turns out to be the best.
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Use a relay
  5. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    ...and I know the 2010 U.S. wiring diagrams are around here if needed. ;)
  6. Mendel Leisk
    42,345
    Yeah you'd want an always-on connection, and then run that into a a relay that's "open" when supplied 12 volts, and connect that relay to a switched power source, say the cig lighter socket in centre console.
    Just curious: what's this for?
  7. bisco
    52,853
    security camera and dead battery
  8. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    The OP asked this same question in the General forum.
    12v Power from cabin. | PriusChat
    Mendel, you and I had the same response.
    OP hasn't been back.
