2010 Prius check engine & other warning lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by whataboutbob, Apr 11, 2023.
  1. whataboutbob
    whataboutbob Junior Member
    74
    16
    2010 Prius 155K miles. I got check engine light a couple of weeks ago which went away after driving around for couple of days. Today, something way more troubling happened while I was driving on the highway. First, the check engine light came on and after a while, 4 other indicators came on, brake system (yellow), electric power steering, master warning, and slip indicators. In addition, the check hybrid system message also showed up on the panel. The engine started slowing down and I felt like my car would stall. It started slowing so much that I thought it might stop on the highway, so I pulled over at an exit, turn the engine off and on again. Only the master and check engine lights are on now along with the check hybrid system message, the rest have disappeared.
    I was able to get the car going again and got the codes checked at Autozone and it showed P261B engine coolant pump B control malfunction. However, on the drive home from Autozone, short distance less 1.5 miles, all the warnings lights disappeared.
    Anyone know what the heck is going on? I don't feel like it's safe to drive since it was stalling out on the highway but now I am not sure a auto repair shop can even tell what's wrong with any warning lights on.
    #1 whataboutbob, Apr 11, 2023
  2. Tombukt2
    Tombukt2 Senior Member
    13,798
    2,501
    Durham NC
    You're inverter pump may be intermittent turning off long enough to allow things to heat up and the code to be thrown and then coming back on whenever and then that may make the code go away until it recodes after it heats again sounds plausible.
  3. Mendel Leisk
    42,250
    Personally I’d spring for a dealership assessment, sooner than later.
    Regarding the water pump code: wouldn’t hurt to replace engine coolant pump (and thermostat); they’ve been known to let go around your miles.
  4. whataboutbob
    74
    16
    Inverter pump as in the coolant pump? Sounds plausible though.
  5. whataboutbob
    74
    16
    Well, we all know it costs an arm and leg to take a car into a dealership and I haven't been impressed with their overpriced service before. However, replacing the pump is probably a good start.
  6. Tombukt2
    13,798
    2,501
    Durham NC
    It's no problem to replace It's just you may need to make sure you get one that will last and apparently aftermarket non-dealer blah blah blah turn out to not work so well or for so long I found that out on my generation 2 once I modified the thing and got the right kind of pump that I wanted up in there It's on autopilot
  7. whataboutbob
    74
    16
    Do you have a good source to get the real part?
  8. ChapmanF
    18,947
    P261B is a code for the engine water pump. Not the inverter pump. The one on the front of the gasoline engine that is responsible for cooling it.
    Although nobody was retrieving the trouble codes at the time you were driving just then, here is my guess:
    The P261B was detected, turning the check engine light on. The engine temperature began to rise because the pump wasn't working.
    There is no normal overheat warning light until a temperature of 120℃, but when there's a water pump trouble code, you won't get there, because the ECM will shut the engine right off at 105℃ if a water pump code is present. At that point the power management control ECU (kind of the orchestra conductor for the car) sets code P0A0F, meaning "I don't know what happened exactly, but there's no engine power", and it is stuck using only the battery to move the car. The battery is very puny for being the only thing to move the car, and the car slows way down and feels like it's going to stop (and will, pretty soon, as the battery drains). Several other warning lights come on at the same time, as those ECUs set codes that mean "just got news that the power management control ECU has set a trouble code."
    You don't want to keep repeating this, because running the engine without its water pump working right is quite bad for it. Strictly speaking, before just replacing the pump, somebody should make sure there's not something simple wrong with the wiring to the pump. But in a 2010 with 155k miles, if it acts like a bad water pump, no one will be surprised if it's a bad water pump.
    #8 ChapmanF, Apr 11, 2023
  9. Mendel Leisk
    42,250
    If an arm and a leg is only worth $100~200, yeah. You've got a nice car, on the cusp of a lot of stuff; something to keep in mind.
  10. ASRDogman
    ASRDogman Senior Member
    8,027
    4,072
    It sounds like your inverter coolant pump.
    You can check the reservoir when the car is running and see if the coolant
    is flowing. But it kinda sounds like it's starting to go bad.
    You pretty much have to remove the inverter to change it.
  11. Mendel Leisk
    42,250
    According to AutoZone (and Google concurs), the code indicates engine coolant pump.
    whataboutbob likes this.
  12. ChapmanF
    18,947
    Yes, the code that was set is specific to the engine coolant pump, I don't see any reason to think the ECM was lying about that, and the rest of the story after the check engine light came on was consistent with what happens when the engine coolant pump has flaked out and the engine hits 105℃.
    Also, inverter coolant pump problems are detected by the power management control ECU directly. The codes it can set for that (P0A93, P0C73, P314A) are all shown in the Diagnostic Trouble Code Chart as lighting both the master warning triangle and the MIL (check engine light). Both those lights would have appeared simultaneously had one of those codes been detected.
    For the OP, the MIL/check engine appeared first, and the master warning only later, when the power abruptly dropped off. That's consistent with the ECM reporting P261B first when it detects the low engine water pump RPM, and the power management control ECU only setting P0A0F ("hey! where's my engine power?") and lighting the master warning after the engine hit 105℃ and the ECM shut it down.
    #12 ChapmanF, Apr 11, 2023
  13. whataboutbob
    74
    16
    This makes a lot of sense. Yeah, I will look into getting the coolant pump replaced, thanks.
  14. whataboutbob
    74
    16
    Well, as an example, I just came across this comment on a Facebook thread on diagnosing/fixing this issue at a dealer
  15. Mendel Leisk
    42,250
    Diagnosis and repair are two different things. If it’s rodents it can be involved, and nobody works for free.
  16. whataboutbob
    74
    16
    True but everyone knows dealerships charge way more than the average mechanic shop and when I used them before to try to diagnose a problem, they came up with nada and I ended up with a hefty bill.
  17. ChapmanF
    18,947
    'cept maybe the rodents.
  18. whataboutbob
    74
    16
    :ROFLMAO:
  19. whataboutbob
    74
    16
  20. ChapmanF
    18,947
    Looks right. Did you try the "select my vehicle" or "check fit" features on that page?
