2010 prius check hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by freebird1, Oct 29, 2021.
  1. freebird1
    freebird1 Junior Member
    59
    Dallas, TX
    getting this on dashboard
    disconnected both HV and 12V batteries and connected
    will update on this issue from mechanic
  2. freebird1
    59
    Dallas, TX
    change Inverter as per mechanic car engine starts but makes clicking noises
    52,754
    did they give you the trouble codes?
    how many miles on her?
    edit: just saw your pic, is that tech stream? is it a hybrid specialist?
  4. ChapmanF
    18,942
    Looks kind of Dr. Prius-like, only on a tablet.
  5. freebird1
    59
    Dallas, TX
    180k miles
    mechanic used tablet for codes as in picture name, found him from classifieds ads in this big city (Texas)
    maybe its drprius app or there are other apps professionals use ?
    He also used a red device towards end of repair to clear abs light
    So i have to see if abs light will come back on later
    Main issue as per him is bad inverter and after replacement its in ready mode good
    #5 freebird1, Oct 30, 2021
  6. Mendel Leisk
    42,239
    How many miles?
  7. freebird1
    59
    Dallas, TX
    177K+Miles
  8. freebird1
    59
    Dallas, TX
    getting all the lights again and engine has rattling sound ,little cold outside ,but does go into ready mode later
    will ask technician to check obd codes clear and his inverter replacement solved code p0a94 or another issue
    these are exact ones before would get check hybrid no ready ,now can get ready but same lights
    these went away after a while ,checked twice same briefly see them but after a little bit they went away and could drive
    #8 freebird1, Oct 31, 2021
  9. bisco
    52,754
    have you ever had the egr circuit cleaned?
  10. freebird1
    59
    Dallas, TX
    mechanic said its not egr problem and didnt want to look after p0300 code,hes not willing to check other issues
    #10 freebird1, Oct 31, 2021
  11. freebird1
    59
    Dallas, TX
    day 2 update
    "p0300 random multiple cylinder misfire detected "
    update from mechanic ,suggested to do blue devil procedure or replace engine,
    he was not willing to look at egr
    if finding another mechanic whos willing to check egr can improve or replace engine is the only option ?
    from below it looks like temporary fix or it could make it worse
    Gen 2 Blown Head Gasket; Seal it with Blue Devil? | PriusChat
    #11 freebird1, Oct 31, 2021
  12. AzusaPrius
    AzusaPrius Senior Member
    2,249
    940
    Fire your mechanic and buy a Carista OBD2 adapter.
    Then download the Dr. Prius app for free.
    The app will give you more prius codes than your mechanics.
  13. ASRDogman
    ASRDogman Senior Member
    8,020
    4,072
    NEVER NEVER EVER use any "sealant"!!!!
    It only causes more headaches and does NOT fix the problem.
    IF you have a blown head gasket, you need to replace it, or have it replaced.
    If that clown won't even look at the egr circuit, find someone who will.
    Perhaps it's time to learn how to do the work???
  14. Mendel Leisk
    42,239
    Yeah turf that mechanic out. If you've got code p03xx, and 177K miles (apologies for not seeing your earlier mention of miles), you've very likely got a failing head gasket, and likely due to a carbon-bunged EGR system, including EGR passages in the intake manifold.
    Finding another mechanic, capable of a leak-down test to determine head gasket condition, would be my next step. If it does turn out to be a failing head gasket, and you follow through by replacing it, get the EGR system cleanined directly thereafter, to avoid a repeat. More info in my signature.
    bisco and freebird1 like this.
  15. bisco
    52,754
    ^^^yep^^^
  16. freebird1
    59
    Dallas, TX
    Update
    New mechanic did another diagnos got p0301
    Replaced 4xsparks and 1st cylinder coil
    After other tests confirmed head gasket is ok , maybe also confirmed tests no egr issue as but didn't get to open egr ,time was short
    But car still rumble on startup and same problem
    Getting new codes to replace coils 1 2 3 4 cylinder s ,only coil 1 was replaced
    P0351 p0352 p0353 p0354
    Odd the rumbling is bad than before but only during startup codes all changing
    Also was told could be clogged catalytic
    And to
    Try lucas cylinder lubricant ,
    guaranteed to pass additives into fuel tank and run till empty
    Techron looks recommended here in forums
    Car runs ok after rumbling startup, haven't gone on highway to check if spees ok to 60mph
    Trying to see if really coils were bad or other issue
    Or the tsb of shaking on startup of 2010 prius but this is >150k miles so may not apply
    Any other things to check
  17. freebird1
    59
    Dallas, TX
    Mechanic tried to do hard reset removing both terminals of 12v batt with jumper cables but stopped as not sure how prius electric would behave
    Is hard reset to clear all codes ok on prius
  18. Mendel Leisk
    42,239
    EGR never been cleaned, 180K miles, P0301? It doesn't take Sherlock Holmes: I think you'll find carbon-bunged EGR, and head gasket leaking coolant into cylinder one.
