2010 Prius cold start?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Yacht Rock Guy, Jan 18, 2026.
  1. Yacht Rock Guy
    Yacht Rock Guy Junior Member
    usa
    hello. It's been frigid cold here in Chicago and my prius seems louder on start up than normal. it has 170k miles. i uploaded a 50 sec video of the start up. i'd appreciate if someone could take a moment to view the video and offer any advise.
    Thank You
  2. indel
    indel Member
    283
    89
    Northwest Indiana
    Seems normal? Rattle from a head gasket failure actually makes the engine shake violently. I am not seeing that here. Check oil level? Starts on very cold mornings are always noisy.
  3. ASRDogman
    ASRDogman Senior Member
    8,038
    4,074
    That is normal, for a Prius.
    If it was knocking, you wouldn't have to get out of the car to hear it.
    Be smart and shut it off the second you hear it. Because it moisture in the cylinder.
    Bad things will happen if you let it knock.
    It might seem louder because of the colder air, and the engine is likely working a little harder
    to warm up.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,992
    6,890
    Texas Hill Country
    Advice vs advise.
    Your video sounds really loud but it is hard to judge from your video.
    Does it clear up and get quieter a minute or two later? If so capture the transition on video.
    Does the engine shake and then get better? Capture that.
    Early hg gasket problems present with a severe metal to metal rattle and the engine visibly shakes due to a hard misfire - both clearing up in less than a minute as the plugs burn off coolant which has leaked in when cool.
    Typically no codes are set as it clears fast. Combustion gas in the coolant testing often provides a false negative and are unreliable on a Prius. If the coolant drops there is an advanced problem. If it does rattle severely twice or more in a month, it would be worth a quality dual view or an articulating borescope inspection.
    If it has a hg leaking there is no real fix other than a new hg. Sometimes it can escalate to a replacement engine.
    #4 rjparker, Jan 20, 2026
