2010 Prius Completely Dead
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BuffaloFan32, Dec 27, 2016.
  1. BuffaloFan32
    BuffaloFan32 New Member
    San Francisco
    I cannot figure out what is wrong with my prius. It is completely dead and no lights or sounds will come from it no matter what buttons I push. I checked all the lights and doors and they were all off and closed so I am not sure why the battery would die. I also tried to jump it with a portable jumper and nothing happened. It seemed to indicate the battery was full. The current battery is about a year old. Any idea what could be going on?
    52,863
    welcome! hard to say. take the 12v battery out of the circuit, make sure the jumper is charged, and try again. a bad cell will prevent the jumper from working.
    it also could be a blown fuse. how many miles on her?
    how does a portable jumper indicate the battery is full?
  3. BuffaloFan32
    San Francisco
    Hi bisco, the indicator said FL and never changed.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Is there a good connection between the battery and connectors? Or the wiring secured? Sometimes a connection can get loose and then nothing happens.
    Do you have access to a multimeter? If so, what is the reading at the underhood jump posts?
    tankyuong likes this.
  5. mastergunnera8
    mastergunnera8 Junior Member
    93
    Read this thread. Hopefully it is only the main fuse and it did its job. Have to be extra careful about jumping a Prius.. Happened to me..but I don't mess with the main electrical parts in a Prius..too dangerous..Had to get it towed to the dealer...I was lucky...good luck to you!!!
    100Amp fuse | PriusChat
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Step by step.
    Get a voltmeter. Measure the battery -directly- across the battery terminals. Not the connection cable terminals. You should see 12V or more. Next try the cable terminals. Turn on the headlamps and measure again across the cable terminals. If the voltage is a lot less, remove the cable terminals and clean the lead terminals. Check again. Check the negative cable where it bolts to the body (rear). If all that is good but you don't see 12V at the "boost point" under the hood, you may have a blown 12V system fuse. It's on the positive battery cable, as I recall.
    It's pretty simple. If the battery is good something between it and the car is resistive.
  7. Mendel Leisk
    42,358
    Testing the battery at the posts with a Solar BA5 will really cut to the chase regarding battery health. A little pricey though. Hmm: only $44 on US Amazon right now.
    As noted by other responders, it could also be connections, cables, fuses. Especially with the jump starter not working either. If the jump starter's for sure good, something's not adding up.
