2010 prius cylinder 2 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Priusprofit, Aug 30, 2018.
  1. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Hey PC, my 2010 prius has 192k miles and has an intermittent misfire.
    About 1 in 5 times that the engine turns on it misfires so bad that it sounds like the engine is blown and about to die.
    The other 4 times out of 5 it runs smooth from idle to 2500rpm it runs like new.
    All I have to work with is a code for cylinder 2 misfire.
    Oil is at good level and looks good, coolant is at good level and looks good.
    Any helpful advice before I go down the diagnostic list?
  2. audiodave
    audiodave Active Member
    800
    272
    US
    Injector or coil. How old plugs? That's the cheapest to change first. Could swap coils to see if it changes cylinder.
    777BETO likes this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Start with plugs and the coil. Clean EGR cooler, piping, and intake manifold. If that doesn’t cure it, then run a compression test.
    m.wynn and Raytheeagle like this.
  4. Mendel Leisk
    42,349
    The easiest part of the EGR circuit to remove and check is the "pipe", watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    If you've not heard of EGR, never touched it before, with 192K miles it it'll very likely be getting pretty clogged.
    If so, from there I'd proceed to a full EGR cleaning, intake manifold cleaning and OCC install. There's videos on those too, same location.
  5. bisco
    52,858
    Whatever happened?
  6. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    I changed all 4 spark plugs and it seemed to run a bit better but problem was not resolved, then I followed instructions from the video above on cleaning the EGR and that made a world of a difference. About 8k miles driven since then it only misfires for about 5 seconds on a cold start.
    Raytheeagle, Mendel Leisk and bisco like this.
  7. bisco
    52,858
    Congrats!
  8. Mendel Leisk
    42,349
    Not quite out of the woods? Did you clean the intake manifold too? There's EGR passages in there too. Video on that at the same location.
    Quote from @Ragingfit :
    Well we're not out of the woods yet, but uh, certainly feeling ok about it... Starting to like the woods.
    #1lightman likes this.
  9. xerox6135
    xerox6135 Member
    170
    94
    michigan
    I am still saying head gasket is leaking into the combustion Chambers
  10. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    My memory says that I did but it's possible I overlooked it.
  11. Priusprofit
    Priusprofit Member
    96
    32
    Long island
  12. bisco
    52,858
    Wouldn’t there be symptoms?
  13. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    I suppose it could be possible but no other symptoms of head gasket failure, time will tell.
