2010 Prius Dies On Startup
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MVTWON, Oct 24, 2022.
  1. MVTWON
    MVTWON New Member
    Michigan
    I recently got a 2010 Prius. Everything works fine until I realized it dies every few days and needs a jump start. I have installed a new battery and the same problem keeps happening. I will depress the brake pedal and see the green light with the power button and when I go to press it the car does not start and dies.
    any help would be appreciated!
  2. jolynf13
    jolynf13 Junior Member
    25
    san diego
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Check the dome lights, the one in the trunk also.
    Since you've replaced the battery, (did you charge it?) it would appear you have
    a drain.
    52,862
    probably a phantom drain
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Loose connection at the battery posts or negative cable on the chassis from negative battery post.
