2010 Prius EGR Cooler Leak
Discussion in 'Gen 3 Prius Technical Discussion' started by Eugene Kurtz, Dec 24, 2022.
Tags:
  1. Eugene Kurtz
    Eugene Kurtz Junior Member
    PA
    After replacing the head gasket in my 2010 Prius, I have a coolant leak where the EGR cooler bolts up to the exhaust. There is a fast drip of coolant at the flange at the back of the cooler. I assume there shouldn’t be any coolant here so the EGR cooler must have an internal leak? Anyone else run into this issue?
  2. ChapmanF
    19,045
    Sounds like an internal leak all right.
    Was the cooler ever subjected to an especially violent cleaning?
    Tombukt2 likes this.
  3. Eugene Kurtz
    PA
    No cleaning, just unbolted and reinstalled as part of the head gasket replacement. The car has ~250k miles and the EGR valve was replaced at 150k. As far as I know the cooler is original but not sure if it was cleaned when the valve was replaced.
    I didn’t notice any external leaks before doing the head gasket and was surprised to see coolant leaking from the flange. Thought I missed a hose clamp.
    #3 Eugene Kurtz, Dec 24, 2022
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I'd suspect that one of the hoses has a bad/loose connection before looking for an internal leak in the EGR cooler coolant system.
    Perhaps one of the hose connections is leaking, and it just looks like it's coming from that back area of the cooler?
  5. Eugene Kurtz
    PA
    I was pretty sure it was from the flange but that’s definitely worth double checking. Thanks for the input.
  6. CR94
    CR94 Senior Member
    2,834
    1,244
    Northwestern S.C.
    Check to be sure coolant isn't leaking from the top hose connection and running down the back side.
    A true internal leak of coolant into the EGR stream could be disastrous.
    xliderider likes this.
  7. Eugene Kurtz
    PA
    You guys were right, it was the hose connection! Thank you!!!
  8. Mendel Leisk
    42,365
    How recently was the head gasket replaced?
    If the EGR components (including intake manifold) are still uncleaned you definitely want to do that, ASAP.
    In the course of cleaning you’ll be able to pressure test the cooler’s coolant passages easy enough. if it doesn’t hold pressure you’ll need to replace.
  9. Mendel Leisk
    42,365
    Good to know. (y) Now clean them EGR components, don't slack off.
    #9 Mendel Leisk, Dec 25, 2022
  10. Eugene Kurtz
    PA
    I just replaced the head gasket this week. The intake EGR ports looked reasonably clean so I just blew out the ports to make sure they weren’t clogged before reinstalling. The pipe from the EGR valve also looked good so I decided to leave that alone for now. Aside from the coolant leak (now fixed by adjusting the hose clamp) things went back together well and the engine is running smooth (no more shakes and rattles on start up). I’m thinking to drive it for a while then maybe consider in the future.
    Is there any downside to waiting for symptoms before cleaning?
    Thanks for all the links, a lot of great info here!
  11. Mendel Leisk
    42,365
    Yes.
  12. ColoPriusV
    ColoPriusV Member
    35
    27
    Boulder. Colorado
    Surprised no one has advised installing an oil catch can yet. OP lives in PA and the amount of oil/water/gas vapor an OCC eliminates from the intake during winter months is astonishing, and especially on an engine with 250K miles, a prior blown head gasket - and quite possibly worn piston rings.
