2010 Prius Emergency Brake Pad Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by not2ez, Nov 10, 2012.
  1. not2ez
    not2ez Junior Member
    Washington
    2024 Prius Prime
    XSE Premium
    I have a 2010 Prius IV, VIN JTDKN3DU9A1011549 and at about 40,000 miles the pad on the
    parking brake arm fell off. I put it back on but it kept falling off. I made sure the square protrusion
    on the inside-right was pressed into the rectangular hole on the parking brake arm. This design is
    supposed to keep it in place but it didn't. So, I ordered a new one from our dealership hoping the
    design would be improved. When it came in I matched it up and it was the same. I didn’t see any
    design changes. The parts clerk told me there was a service bulletin out on this part and that it stated that if it fell off it was to be glued back on. That was an unsatisfactory solution so I asked the clerk to find another part that would work. He found another brake pad that he said should work but didn't state which year or model Prius on which it was to be used. The part number for the second pad he ordered is 46252-47010, Pad, Parking Brake.
    When the pad arrived I compared it to the pad that was on my car when it was manufactured. The replacement pad was designed slightly different in two ways. First, the piece that inserts into the side of the parking brake arm was rectangular in shape, providing about 1/8" overlap on the inside top of the brake arm. Second, on the back one of the corners has a triangular flap of rubber that makes it more difficult for it to fall off. (The attached document shoes both the original and the pad I used to replace it.)
    Although this is not the correct part for my car, per the online parts catalog, I believe it is better than the one that was on it when manufactured. It is not necessary to use glue on it to keep it in place.
    The reason I decided to post my experience is that I believe Toyota should have issued a service
    bulletin that calls for the original part to be replaced by the part 46252-47010, not to glue the same
    type off pad in place. The old pad could be easily replaced by the new pad during an oil change, or
    other scheduled service.
  2. El Dobro
    El Dobro A Member
    7,102
    3,281
    When I stated reading your post. I thought you were talking about the brake pads. To avoid confusion, that's usually called a parking brake pedal cover.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    El Dobro, thanks for the translation.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I thought the same thing :)
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Doubtful that the little extra corner would make much of a difference. Keep in mind that the rubber is new and soft right now. Once it ages, hardens and shrinks, you might end up in the same boat.
  6. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Glue it, forget it. One minute's job - as I did.
  7. El Dobro
    El Dobro A Member
    7,102
    3,281
    Glue, double-sided tape, etc.. I wouldn't sweat it too much.
