2010 Prius engine noise on startup (cold day)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zmoose, Jan 31, 2023.
  1. zmoose
    zmoose Junior Member
    Rochester, MN
    It was -10F today but currently 7F. I've lived here a long time in cold weather and never heard this car sound like this. Any ideas what it may be? I plan to wait for this weekend when the weather will be warming to try again.
    2010 Prius bad engine noise - this due to cold weather? - YouTube
    52,854
    How many miles on her?
    52,854
    Is the cat still there?
    have you cleaned the egr circuit?
    are you losing any coolant?
    have you followed the maintenance schedule?
  4. zmoose
    Rochester, MN
    113k
  5. zmoose
    Rochester, MN
    Its been in garage since I drove it last (2 or 3 days ago) so I assume the cat is there.
    I don't see any leaks.
    I'm not sure what EGR circuit is.
    I've done the maintenance my local Toyota Dealership has suggested over the years. Including regular oil change maintenance.
    I also checked the oil level which is fine.
  6. bisco
    52,854
  7. Mendel Leisk
    42,345
    The EGR is Exhaust Gas Recirculation, a system comprising two components bolted on at the top/left corner of the engine. It takes exhaust gas from the exhaust manifold, cools it somewhat, runs it through the intake manifold where it goes back into the combustion chambers, under certain load conditions.
    It was introduced with 3rd gen, is prone to clogging with carbon, and head gasket failures are a common occurence when it's clogged.
    That knock at start-up is often due to coolant leaking past the head gasket into the cylinders.
    The start-up knock can also be caused by running the engine cold for just a few seconds, then shutting down at letting it sit. Knock happens at next start up
    Any warning lights or codes? Is coolant level in the engine coolant reservoir stable?
    113K is a good time to get on the EGR cleaning, including the intake manifold. Consider an oil catch can too.
    See first two links in my signature.
  8. zmoose
    Rochester, MN
    Yesterday I did start it and it ran for a few seconds before I shut it off because I noticed my wife's car was behind me and we took her's instead.
    If I started it now and its making that noise should I let it run awhile to see if it clears up?
  9. Mendel Leisk
    42,345
    If it knocks I’d shut down. If it doesn’t, odds are better it’s due to that momentary start up.
    still, EGR cleaning is good to to do ASAP.
    Again, is coolant level in reservoir stable? Either way, keep an eye on it.
    head gasket integrity is commonly tested with boroscope inspection of cylinders with coolant system pressurized (looking for coolant trickle), and/or leak-down test, where cylinders are pressurized one at a time, with special gauge set, with piston at TDC of compression stroke. Mechanics should know those.
    zmoose likes this.
