2010 Prius: Engine quit, P3190, but starts after two weeks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Al Beetle, Jan 17, 2021.
  1. Mendel Leisk
    42,347
    Looks like there’s an arrow on the lid too. Maybe a good place to start prying.
  2. Al Beetle
    Al Beetle New Member
    Milwaukee, WI
    Any recommendations on where I should order a fuel pump from?
    I hear that the 2010-11 fuel pump connector is different from the 2012-2015 fuel pump connector.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,968
    Texas Hill Country
    You can get an aftermarket from most auto supplies and Amazon. Or an OEM 23220-47010 pump or 77020-47081 assembly from several online or local dealers. I would check the connector issue. Did you prove the pump was bad?
    #23 rjparker, Jan 24, 2021
  4. Al Beetle
    Milwaukee, WI
    The fuel pump makes loud noises and then stops running. If I tap the top of the gas tank, I can get the pump to run again.
    I ordered the Delphi FE0670 fuel pump from Rock Auto. The connectors do NOT match.
    I need the harness adapter or I will have to modify the connector to fit the pump.
    The install has been easy.
  5. Al Beetle
    Milwaukee, WI
    I did not check the relay. Where can I find the fuel pump relay?
  6. rjparker
    11,104
    6,968
    Texas Hill Country
    The relay is up front in the engine compartment. It is unlikely to be the problem if tapping the fuel pump makes it work again. A2F40521-3356-44EE-9487-F3A007C17172.jpeg
  7. Al Beetle
    Milwaukee, WI
    New fuel pump is installed. I can't hear the fuel pump running, which I am going to assume is a good thing!
  8. rjparker
    11,104
    6,968
    Texas Hill Country
    Sounds like you win and the dealer who said bad hv battery is suspect. Good thing the hv battery refurb guy was honest.
  9. Al Beetle
    Milwaukee, WI
    4,000 mile update:
    Vehicle runs without issue!
    I need to check the seal on the sending unit. When I take sharp turns, I sometimes smell gas a few minutes later. I pulled the back seat and tank cover and found gasoline on top of the sending unit.
    bisco, kc410 and privilege like this.
  10. privilege
    privilege Active Member
    659
    169
    Birmingham
    very very cool thread. thank you for documenting it here and coming back with an update!
    I was skeptical of the fuel pump but your diagnosis skills exceed mine obviously.
    very cool !
