2010 Prius Engine Rattling. Should I be Concerned?
Discussion in 'Gen 3 Prius Main Forum' started by JJC123, Oct 13, 2019.
  1. JJC123
    JJC123 New Member
    Chicago
    I have had my prius for about 9 years (it recently reached 90,000 miles) and have never had this problem and was wondering if someone also has experienced this or if I should take it to get checked. I recently took my car on a total 6 hour trip this weekend (no issues). When I got in my car again today, it started to make this revving/rumbling sound that was a bit jerky. You could even feel the car shake a little in time is the jerky rumbling. It eventually settled down, but it happened again when I got home and placed the car in park. (I occasionally happened lightly while we were driving as well). It sounds like it is the engine, but the engine light didn't turn on. Is it possible it has to with the battery charging or is there something wrong with engine?
    Thank you!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • Is this the first time you’ve noticed the behavior?
    • Is the coolant level stable for the engine?
    • Does your Prius consume oil?
    • Has the egr circuit been cleansed?
    Good luck and keep us posted (y).
    Pluggo and Mendel Leisk like this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    It's not the battery. Hopefully, it is not too late to clean the entire EGR circuit. Your head gasket may be at stake, as per @Raytheeagle 's comments.
    Raytheeagle likes this.
  4. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    Mafs, map, and throttle body being dirty or oil saturated will cause these issues also especially at idle. Seen it many times when oil was overfilled or the pcv is stuck open
    RMB likes this.
  5. bisco
    52,858
    worry? no. concerned? yes.
  6. Mendel Leisk
    42,351
    @JJC123 what's your situation, are you mechanically inclined, doing some maintenance yourself? Or strictly dealership serviced? Somewhere in between. Let us know.
    The aforementioned Exhaust Gas Recirculation circuit was introduced in 3rd gen, and had a major revamp with 4th gen, likely to address shortcomings. Specifically: that the dang thing inexorably clogs up with carbon, and as it does engine temperatures climb, head gaskets fail.
    Also mentioned above, the Positive Crankcase Ventilation system tends to dump a lot of oil and gunk into the intake manifold, possibly accelerating the the EGR clogging.
    The EGR also has passageways going through the intake manifold, and they clog as well.
    #6 Mendel Leisk, Oct 14, 2019
  7. JJC123
    JJC123 New Member
    Chicago
    I just go to the dealership and have them to a check up every 6 months. This is the first time that’s happened.
  8. Mendel Leisk
    42,351
    It's getting to where the only way third gen ownership is viable is if you're a game DIY'r. Ok, one alternative: a reasonably priced shade-tree mechanic who makes house calls, and is willing to learn. Or, an evangelistic Priuschatter that holds EGR "clinics". On the west coast @Raytheeagle has been coaching people through this, has it down to a 4~5 hours for the EGR. And maybe 2~3 hours for the intake manifold.
    The dealerships and Toyota have effectively turned their backs on the EGR issue. Have a read and check out the links:
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    kidfried, RMB and NutzAboutBolts like this.
  9. JJC123
    JJC123 New Member
    Chicago
    Thank you all for replying and your help! In the end, I took my car to the dealership today. It was the EGR, which they replaced as well as well as another part. It turns out they my car qualified for an extended warranty, which covered the cost of both the part and work! (Which I didn’t expect since the car is already almost 10 years old.
  10. bisco
    52,858
    with no dash lights on?
    wow, congrats!(y)
  11. abdullah arslan
    189
    79
    just got home thanks to EV mode. After a 8-9 min drive, picked up my order, waited in park mode 2 minutes or so, then as soon as I started to move, the engine started to rattle and shake. I thought it ll pass after a few seconds but it hasn't. I pulled over and charged the hybrid battery and was able to get home with hazard lights.
    No engine lights on
    The s.plugs changed in summer ( no egr cleaning that time)
    Is it EGR do you think? I also consider misfiring but this never happened so far. Only thing I can say that it sometimes rattles on low speeds for a second or so
    Checked the oil, it's fine and same as before
    #11 abdullah arslan, Dec 23, 2020
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Your symptoms sound consistent with engine misfire. There are many things that could cause misfire - ignition coils are near the top of the list, but that's just a guess. Using a scanner to check data or codes in the engine computer would be a first step.
