2010 Prius Engine Running more loudly than before
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Web Storm, Jul 18, 2025.
  1. Web Storm
    Web Storm Junior Member
    Seattle, WA
    The engine on my 2010 Prius (108k miles) is running more loudly than it was before. It's been this way for the last seven months. Started in the winter but it's still happening in the summer.
    It's not knocking, and it's consistently louder than usual whenever the engine is on (i.e. I don't need to be in the red zone of the power bar). There are no OBD2 codes.
    I have searched on the forums here and online but haven't found many posts about just the engine running more loudly.
    I don't think this is related but the loudness started happening within a week after I had my inverter coolant flushed by a dealership. I distinctly remember when it started – I was just pulling into a parking lot to park and noticed the engine was louder than normal, and it's been that way ever since.
    About a month before I had the inverter coolant changed I cleaned out the intake manifold and replaced the gasket, and cleaned the EGR pipe (just the pipe, not the full circuit).
    About a month after I had my inverter coolant changed I also changed the spark plugs to the SC16HR11 ones and did a regularly scheduled oil change but that hasn't helped.
    There don't seem to be any other actual noticeable issues as a result of the loud engine but obviously I want to make sure the engine is not running too hot and cause the blown head gasket. I'm not losing any coolant and the coolant levels are normal.
    Anyone have ideas on what it could be?
    #1 Web Storm, Jul 18, 2025
    52,806
    exhaust leak?
    Brian1954 likes this.
  3. Web Storm
    Seattle, WA
    Hmm, with an exhaust leak should I also expect to smell fumes either inside or outside the car?
  4. Mendel Leisk
    42,304
    Better get on that ASAP.
  5. PriusCamper
    PriusCamper Senior Member
    13,427
    5,421
    Pacific Northwest, USA
    We'll need you to be way more detailed about what you mean regarding engine running loud. It's currently way to vague... where are you in relation to vehicle when it is loudest? Have you examined the entire exhaust system to ensure its not a leak? Basically, people's ears play tricks on them and the constantly drive auto mechanics crazy with claims of strange noises they can't describe very well.
  6. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    I would have a muffler shop check out the whole exhaust system. Mufflers can internally corrode and lose their muffling capability without an actual exhaust leak happening.
    Web Storm likes this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,046
    6,923
    Texas Hill Country
    ... double post
  8. rjparker
    11,046
    6,923
    Texas Hill Country
    If it is really louder now the egr pipe could be missing a gasket or the gasket is not in correct. That would be loud as it is an exhaust leak.
  9. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    That's right. Mechanical clatter or exhaust noise? What frequency? What conditions make it loudest?
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    Should send a link of a video of your noise issue, it’s hard to figure out with just a text message.
    johnHRP likes this.
  11. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    video is the only way to tell. My car also a bit louder recently after I clean the AC evaporator. It turns out the rubber grommet was dropped somewhere after I put the rubber drain hose in.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Come on everyone, use your imagination !
    johnHRP likes this.
  13. NutzAboutBolts
    1,756
    1,788
    Bay Area
    :ROFLMAO::ROFLMAO:
  14. bisco
    52,806
    i'm imagining that op is interacting with recommendations
