2010 Prius Engine Shaking / Engine Vibration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Smiling Bob, Mar 9, 2016.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    Looks like you're referring to the EGR sub assembly correct?
  2. Mendel Leisk
    42,293
  3. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    I think you guys are on to something here about just replacing the whole unit - EGR valve and radiator/heat exchanger. I believe this is why people who have cleaned the IM, throttle body, and EGR pipe continue to have problems. The radiator part is supposed to cool the exhaust gases enough that when added to the normal intake charge you get better mpg and reduced emissions. BUT if the radiator is all carboned up where the exhaust flows through it, less heat from the exhaust will be absorbed by the radiator, then when the EGR valve opens all four cylinders (instead of one) get a nice blast of hot exhaust which results in pinging which then the ECU pulls timing and you get reduced power.
    My other hypothesis is that the shuddering/shaking/vibration is caused by a resonance caused by the ECU trying to crack the EGR valve when conditions demand, but then having to close the valve and pull timing when the knock starts. Then the whole process repeats itself. Whew! What do you guys think?
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I'd say clean all the oil out of throttle body that would cause vapor lock
  5. Mendel Leisk
    42,293
    All I can think is if the radiator component is almost completely carbon clogged, it can't be behaving within spec.
  6. Former Member 68813
    3,524
    983
    US
    LOL, you don't know what vapor lock is, do you?
  7. tankyuong
    1,555
    662
    Central MO
    I meant hydro lock
  8. laurentiu
    laurentiu Junior Member
    Constanta
    2012 Prius+ MPV
    We can find that was eventually solve the problem?
  9. bisco
    52,801
    can be a number of different problems.
  10. hrinkon
    hrinkon New Member
    New Jersey
    2016 Prius c
    Usually this is related to the egr, the egr in the prius is a little different and causes carbon build-up. sometimes in the valve its self or the intake manifold.
  11. JCEze
    JCEze Junior Member
    HUntsville, AL
    Bob,
    Did you ever solve the problem? Did your car happen to vibrate badly at idle when the car is first started?
