2010 Prius engine?
Discussion in 'Gen 3 Prius Main Forum' started by toyotareference, Jan 13, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    One of my friends used to fly for San Juan Airlines up in the Sound. They flew 210s and fairly light twins. One day he was loading mail bags while a few passengers waited in the plane. He threw one more bag into the aft cargo hatch and the plane tipped back onto the tail skid: "Better move that one to the front." Talk about weight and balance.
    Tom
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Curb weight (kerb weight) is the vehicle's weight with a fuel tank of fuel and other necessary liquids, but with no passengers or cargo. A European directive states that a 75kg driver should be added.
    Gross vehicle weight is the weight that should not be exceeded once passengers and cargo are added.
    IIRC the brochure I have from last March (UK spec) quotes kerb weight as 1300kg, gross vehicle weight as 1725kg for a total of 425kg passenger and luggage capacity.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The other two have the same GVWR 3980 lb value.
    GAWR FR 2270 lb
    GAWR RR 2175 lb
    total 4445 lb
    What does that mean?
    Can anyone show us the current Prius's label?
    Ken@Japan
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Sorry, did I not imply that? Curb weight being empty usable weight (w/ gas, oil, etc.) will determine/limit carrying capacity as "useful load".
  5. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    And CG location too?!! Can't let those front wheels float clear of the ground you know, like the "matatus" do in Kenya.
    But that's a whole other story!
  6. qbee42
    18,058
    3,081
    Northern Michigan
    We will have to be careful with that with the new 2010. All of the extra horse power may cause us to do wheelies (tricky in a front wheel drive).
    Tom
  7. HTMLSpinnr
    5,341
    920
    251
    Why am I getting images of retrimming the car when the kids shift position in the back seat? Should I be concerned about a "stall" if I overload the hatch? :lol:
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    current is 3790 or something like that... it is maximum weight of the vehicle, together with all the occupants... it basically means that Prius has not put on a lot of weight, despite all the options :)
  9. qbee42
    18,058
    3,081
    Northern Michigan
    Deep stall. You may not be able to recover. On the other hand, if you put too much weight up front, you won't be able to steer around corners.
    Tom
  10. Patrick Wong
    18,210
    6,515
    GVWR = Gross Vehicle Weight Rating, or maximum allowable weight of fully-loaded vehicle including passengers, cargo, etc.
    GAWR = Gross Axle Weight Rating, or maximum allowable weight that each axle can bear, measured at the tires.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    I didn't know that last one and I weigh vehicles as part of my work.
    Here we use
    UL = Unladen mass = Mass of empty vehicle
    GVM = Gross Vehicle Mass = maximum allowed mass loaded.
    GCM = Gross Combination Mass = Maximum allowed mass of loaded vehicle and any trailer with its load.
    Axle Mass = allowed mass that may be transmitted to the ground through the tyres on that axle.
    All masses are measured between the tyres and the ground under the earth's gravitational influence.
  12. qbee42
    18,058
    3,081
    Northern Michigan
    Driving under the influence of gravity? Isn't that illegal? ;)
    Tom
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    That's what we a do when we step out of the pub and fall flat on our faces. Oh wait, that's succumbing to the forces of gravity and alcohol.
    Sorry my bad.
  14. qbee42
    18,058
    3,081
    Northern Michigan
    I hope the new administration can get congress to repeal the law of gravity. I'm really more into General Levity, which is the opposite of Specific Gravity.
    Tom
