2010 Prius EV mode Hack
Discussion in 'Gen 3 Prius Accessories and Modifications' started by f1racer, Jul 2, 2009.
  1. 2010_Prius_Owner
    2010_Prius_Owner New Member
    110
    24
    Philadelphia
    If Toyota set the kick out of EV mode at 25 mph, it would be to limit the current drain on the battery and charge dropping below 20% to keep it from exceeding conditions that would shorten it's life. What temperatures will the batteries be at up hill at 50 mph? I would imagine they have done a lot of research on how to get the most years out of these batteries. Sure they could set that kick out at maybe 50 mph, but will those batteries still be working good in 5 years or 10 years? They warranty the Batteries to 8 years, I''m sure they don't want to see these batteries coming in for warranty replacement at their cost.
  2. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    I don't understand the need for EV mode other than if you're moving the car in the driveway or maybe moving because you're blocking someone else in. If I'm going to be driving for more than 30 seconds, I just keep it in ECO mode all the time. I routinely accelerate up to about 40mph in ECO mode without using the ICE.
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Oddly, we're getting an increase in EV mode speed limit: 2G was 29mph, 3G is 31mph. I'm not sure if those are indicated speeds; I've seen suggestions that the 2G speedo reads 10% above calculated speed over ground, while 3G is only 5% optimistic.
    The software clearly is able to tolerate a certain amount of variation in this parameter, so I guess it's just whatever your jurisdiction is willing to permit. 31mph is a little over the UK's default urban speed limit of 30mph, and closer to the more typical 50km/h speed limit used in European countries.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    25mph is the residential speed limit here in the US. Interestingly enough, NEV's like golf carts and such in AZ are permitted on roads up to 35mph.
  5. f1racer
    f1racer New Member
    CA
    Toyota Warranties these batteries for 10 years. a clip from Toyota's website:
    "Hybrid-Related Component CoverageHybrid-related components for hybrid vehicles are covered for 8 years/100,000 miles. The HV battery may have longer coverage under emissions warranty. Refer to applicable Owner's Warranty Information booklet for details." This will depend on individual state laws, I've heard in CA, it's 8 yrs. up to 150K miles.
    Can anyone validate?
  6. f1racer
    f1racer New Member
    CA
    Don't understand how you're able to accelerate up without ICE kicking in, and not be in people's way. For me, Eco is so slow, it's not usable, not practical, and in some ways in-considerate of other motorists on the road. The few drops of gas I save, may not be appropriate savings method. When you first start up the car, is when gas is expended the most, that's why I'm using EV, and in situations when my batteries has high charge, and I know it will be agian shortly, due to the predicted upcoming driving condition. I'd like to be in a situation where gas is used minimally. On a 5 mile stretch to dinner from my house, I averaged 92.9mpg, using a combo of eco, and EV, but I was a little slow getting up to speed. Since then in default mode, I've only managed 70+ mpg.
  7. f1racer
    f1racer New Member
    CA
    yeah, I'm thinking the same, it must be a jurisdictional issue, not technical capability of the car that has different limits. THEREFORE, there must be a way to lift that limit, and get broader use of EV mode. ideas anyone?
  8. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Suggest you allow ICE use during acceleration, then use the gas pedal to induce stealth mode (up to 45 mph) at cruising speed. That way you minimize conversion losses while accelerating normally. No need for EV button for this.
    No free lunch on using the chemical energy.
  9. f1racer
    f1racer New Member
    CA
    thx for the tip, it's starting to make sense to me, how to maximize mileage on the new Prius. First hybrid, definitely a learning curve. cheers.
  10. Tideland Prius
    16,683
    The battery juice ain't free. Unless you're using EV Drive Mode (the proper term when using the EV button) on top of a hill/mountain and intend to drive down that hill/mountain, you're using either the engine or whatever regenerative braking you can get on a flat road to charge the battery. The conversion losses there are more than what you gain by toodling around in EV Drive Mode.
    It's far better to use the gas engine to get up to speed and then glide (which is like EV Mode but except you're not using the battery and only using momentum. Isn't that better?). It's a misconception that the media plays (cause they're thinking exactly what you're thinking.. EV = no gas = better mileage).
  11. taftjr
    taftjr New Member
    72
    Marlborough, MA
    I have found that EV mode is very good for accelerating from 0 to 25 mph as it allows you to use far more acceleration than in stealth mode. You can see this by watching the Hybrid System Indicator bar go well beyond the center ECO line and at times all the way into the PWR area while still on electric! (I call this a EV burst)
    This only lasts until 26MPH but it gives you a short boost of power without using the ICE if you are accelerating to normal speeds after sitting at a light. This over the course of a long trip and many stop lights can save many MPG as getting up to higher speeds will regenerate the battery anyway. I now use this technique when accelerating from all stops. (battery power permitting of course)
  12. Tideland Prius
    16,683
    oops. ksstathead already said I wanted to say.
  13. Tideland Prius
    16,683
    umm.. not really since the engine will be spinning at a higher rpm to produce power to move the car and charge the battery. Once it's "full", then it'll settle down to the lower rpm for cruising. Again, there's no free lunch.
    The battery and electric motors are already helping out by moving the car from 0km/h when driving normally. The engine takes a split second to kick in and by then you're already at 5km/h so the initial load of moving the car from a stop is already taken off the engine so you're saving fuel there. Once moving, let the engine propel the car.
  14. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Sorry to burst your bubble, but this is absolutely wrong and a sure way to lower your overall MPG. Please read the rest of this thread and others like it to learn about the proper use of EV mode. For any trip longer than a quarter mile, you should use the ICE to accelerate at a moderate rate (exact RPM range to be determined later by G3 Prius enthusiasts).
  15. THD
    THD New Member
    La Crosse WI
    I
    the first month my ev mode worked up to 25 mph, now it kicks out at 10 mph, exact same situation, not too cold, not too fast, no hill, it has just changed, and for those who do not understand why the concern, it was fun driving 3 to 4 blocks on electric only but now it doesn't work, dealer didn't know why
  16. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    EV has two "modes":
    1. Until the ICE (engine) is warm (70C), EV mode will only work to 10MPH, then shut down ("excessive speed")
    2. Once the car is warm, EV will work to 25MPH
    EV will not work first thing - unless you turn your car on, then quickly put it in gear, then press EV.
    That said, it also has more than 2 quirks :rolleyes:
    There's another EV thread that details these facts...
  17. Boji
    Boji Junior Member
    59
    Ottawa, Canada
    I was just thinking about this the other day! My cousin is a ford sales rep and was bragging about how the Fusion goes to 47 mph and the Prius only goes up to 25 mph, and then saying it was because of Ford's superior engineering... it just sounds like bogus to me; after all, didn't Toyota sell their technology to Ford a while back? Is there something I'm missing? Perhaps the Ford Fusion battery won't last as long as the one in the Prius because it's subjected to more abuse?
  18. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    There is no need to put it in gear. I often will wait for my kids in the car, and will simply get the car into 'Ready' mode, and quickly hit the EV mode button. That way, I am able to wait comfortably for them in the car, open the windows, and listen to music, until they come out. The one time I also ran the A/C, it did cycle out of EV mode, which I would have expected, and starting running the engine in order to power the A/C.
    I still do not know if running the ICE when in park will charge the batteries, or only run accessories? Does anyone know this for certain? I have asked 4 times on the blog, in other posts, and have never seen an answer to this. We know that in 'N', the electrical disconnects. How about in 'P'??
  19. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    EV mode is limited to 29,82 MPH (48 kmH in Europe)
    Have a glance at this mini website (it's in English):
    La nouvelle Toyota Prius 2009 or go on Toyota.be(lgium)
  20. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I'm almost certain the car will charge in park, but not neutral. If the battery is depleted in neutral, you will get a message that tells you to put the car in park, I assume this is so the battery will be charged
