2010 prius: flashing display, failed to start
Discussion in 'Gen 3 Prius Technical Discussion' started by pbk5621, Jun 21, 2019.
  1. pbk5621
    pbk5621 Junior Member
    Today, my prius failed to start. I unlocked the car without a problem, however only the driver's door would unlock. When I pressed the start button, the display turned on and flashed intermittently. The engine failed to start and nothing else happened. I am not sure which part of the vehicle is failing....
  2. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    Check your 12 VDC battery first. If it's dead or near dead the car's computers will not boot up. Check you FOB battery as well.
    CR94, RMB, Raytheeagle and 1 other person like this.
  3. Mr. Prius
    Mr. Prius Junior Member
    82
    24
    Time for a new inverter?
    iPhone ?
    52,854
    no idea. start with the 12v health as mentioned above
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No codes, no go.
  6. Mr. Prius
    82
    24
    Just the 12v optima battery which was 3 years old. Phew
    iPhone ?
