2010 Prius "floaty" and poor directional stability at highway speeds
Discussion in 'Gen 3 Prius Main Forum' started by Technigogo, Feb 14, 2014.
  1. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Same here , I have an early 2010 liftback. No problems wandering, running the original 15 inch Yoko Avids, replaced with Goodyear Fuel max. Both run at 40-44 psi. 40,000 + miles Might be different traffic or road conditions ???
  2. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    DtEW,
    I have a TRD sway bar ordered that will be here Friday. I will install this on Saturday. At this point, I have decided to keep the car regardless. I enjoy too much about it and the fuel mileage to look elsewhere. Hopefully I will fix the problem or just get used to it. I may pass it down to the kid in three years and get a Lexus 200h, though.
  3. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    I had a 2010 III and it was very unsteady at freeway speeds. I now have a Persona with the 17 inchers and the difference is remarkable... very stable at all speeds, handles much better, corners well. It made all the difference. Yes, I do take a hit on mileage but well worth it to me.
  4. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    How much of a hit do you take on the fuel mileage?
    SCH-I545 ?
  5. socal13
    267
    Altadena CA
    Probably about 3-4 mpg.
  6. hlunde
    hlunde Member
    419
    75
    My Prius is similar. While I would classify its handling as "safe", I do fine the lack of precise tracking annoying. To me, what the vehicle needs is independent rear suspension with an appropriate amount of passive rear steer. I'm also wondering if the electric power steering is actually less precise on-center than traditional servo-hydraulic. I think that electric has to potential to be as good or better than servo hydraulic, but the latter has been around so much longer and has had the opportunity to become very refined.
  7. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    some quick thoughts?
    1. Does the problem of vague steering and road feel persist with no load in the cargo area?
    2. The Michelin Energy Saver a/s have a tendency to wander until they break in (read it somewhere in a review) - did the problem exist prior.
    3. what happens at the same speed with an extra passenger in the front? Slower speed 50-55mph?
    4. have you tried putting the 150lb of cargo in another Prius to see if the problem persists. POE (process of elimination) would tell you if the cargo is the issue.
    5. The max tongue weight load (trailer hitch) is 200 lbs. so i am thinking the extra 150 weight in the back is lifting the front of the car up enough to substantially effect the handling. Perhaps the way the car is sitting could be putting extra downforce of air at speed under the frame. etc. In Motorcycles we have Preload adjustments that changes the spring tension with the rider on the bike. So if the preload is soft then the bike will settle down further with the rider weight, thereby lifting the front up. It essentially changes the geometry of the bike and lightens the front end. Conversely, adding 2-3 clicks of preload to a motorcycle will stiffen the rear thereby lifting the rear of the bike with the addition Pillion, luggage, etc. So a thought is that with your weight and the extra 150 of weight in the rear it is changing the CG (center of gravity) and altering the WB (weight and balance) of the car. Not quite sure of the weight distribution of the Prius, but it is not neutral 50/50?
    The point of this above dissertation is too examine the inherent issue of the car: the suspension of the car quite possibly could be causing your issues??? When i went into the dealer to ask about pulling a trailer the service tech - first words of advice was "suspension - rear suspension" to support the extra load. He implied that was the weak link, not the torque of the motor or the CVT?
    6. have you tried putting a known good set of wheels and tires on your prius and driving with and without a load.
    7. Alternatively, have someone swap Priuss and drivers see if it the problem still persists? Don't know if it is your driving inputs or expectations?
    8. if the problem persists i would bring the car to a frame and body shop and have them look the car over... If you have any buddies in the body shop business they can use a micrometer and check the paint thickness over each of the panels in various quadrants to see if there is any statistical difference in the paint thickness - which would tell you if a side or a panel was repainted. The body is a unibody construction so it is difficult to fix without the proper french Celette jig. It is not a cheap jig and you need someone that knows how to work on unibody frames. When i was much younger i worked at a salvage yard, major collision shop that worked on Porsches. I quit after i found out the guy was a crook and stealing Porsches and changing vins, etc...
    FWIW - it kind of sounds like how a Prius drives with 15" wheel, Vague, save for the fact of the car launching right or left. In all due respect the Lexus is CT200H is a prius (a sheep in wolf's clothing, hoofed with 17" wheels) and i don't think it suffers from any anomalies you mentioned.
  8. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    priusdonkey,
    1. I have not had an opportunity to do a side-by-side comparison on same road with/without load to find out. One reason I have not "made" the time is that I won't do anything about the load I have to carry. It has to go with me regardless. I have thought the same curious thought.
    2. Yes, the problem occurred with the Bridgestone EP20 that was on the car when I bought it used.
    3. It does seem to be drastically diminished with an extra passenger in the front. Realizing this has led me to the idea that this is load/weight/balance related. Slower speeds are less "floaty".
    4. I have not had the opportunity for that yet
    5. I'm with you on this. Maybe if we are both thinking that then it might be valid. I plan to install the TRD rear sway bar on Saturday to see if this quietens the rear end. I am not totally opposed to TRD springs if it will fix the problem. I am really shying away from the 17" tires because: a.) I *just* put on new tires for $500 b.) I don't want to take the fuel mileage hit that everyone reports
    6. No but since I had the problem prior to the new tires, I doubt it's the tires. It could be me, I realize that but I don't seem to feel this in my Suburban or my wife's new Forester.
    The frame idea: I don't *think* it has been wrecked. Two reasons: no evidence in the electronic history of the car and also, as a Ford dealer used car manager for 10 years, I can spot paintwork and such pretty well and I see none.
    I like your analytic approach to this. Thank you. I was afraid I was over-thinking some of this but you have given me confirmation of these suspicions of weight and load. I will report back after my sway bar install. I also may have an opportunity to do a comparison tomorrow with and without the load in the cargo area.
    Tandem Rider likes this.
  9. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    How many seconds can you go at freeway speeds with no steering input? Straight road, before it wanders out of the lane.
  10. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    3-5 seconds (taken from my memory)
  11. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    I installed the TRD rear sway bar tonight. I will road test tomorrow.
    iPad ?
  12. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    IT WORKED! I just test drove my Prius after the TRD Sway Bar install. It drives fantastic! Even in heavy crosswinds it tracked straight and never felt unpredictable. I am SO HAPPY to be happy with this car now.
    Here are the things I did to make it perfect for me:
    1: remove the stupid hubcaps and buy Toyota center caps
    2: luckily the backup beep was already fixed before I bought it
    3: installed the 545T Auto Lamps system (I was constantly forgetting to turn lights off)
    4: installed OEM style fog lights
    5: installed TRD rear sway bar
    6: windows were already tinted which looks good on any car but looks doubly good on black
    7: installed rear bumper protector (I always have cargo in the back so this will help protect the looks)
    Now, I REALLY REALLY like my car. :)
    WE0H likes this.
  13. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    I wish the steering angles where more adjustable on the Prius.
    I know what you are describing with the gen 3 road manors.
    I switched to 17" rims with summer tires and changed the struts on my 2010 Prius. It helped a lot.
  14. Mike500
    Mike500 Senior Member
    2,593
    767
    Chassis braces are simple and easy to install. Over the past two years, I have made and developed many of them.
    They are simple "bolt on" installs that take about 20 minutes.
    While I was a skeptic at first, I am sold on them.
    Just search "chassis brace" in the search function on the menu.
    The Cusco strut tower brace, although harder to install, also helps.
    WE0H likes this.
  15. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Rude person's, I may consider one in the future but I am not sure what it would do for me. I really like the way it tracks now so I'm almost afraid to add anything to the recipe.
  16. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Car Compulsive, thank you for your suggestion. I followed your lead and damned if you ain't right! Problem Solved! You da man! Thanks again!
    car compulsive likes this.
  17. WE0H
    WE0H Senior Member
    3,247
    528
    To me a non-Plus Performance feels like it has huge amounts of rear steer making the car a handful to drive in heavy cross winds, rutted Interstates, and having to pass big trucks or having one blow past you. My Plus Performance tracks well bone stock. Toyota should include the rear swaybar as stock equipment.
    Mike
    Somewhere on my phone ;-)
    Technigogo likes this.
  18. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    Why would I be so foolish as to take my hands off the steering wheel when I'm driving??? All I can tell you is that I don't seem to have to correct with the steering wheel any more than with any other car I've driven.
  19. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    Could be the Plus equipment, could be the Plus setup/suspension alignment.
  20. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Is the TRD rear sway bar a good upgrade for a 2012 II or should I save my money?
