2010 Prius Four - Oil Kit Compatibility?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AlanInAustin, Jun 13, 2012.
  1. AlanInAustin
    AlanInAustin Junior Member
    16
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    "Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be ..."
    What the hell? You want the oil in the "motor block" where it lubs the things that need lubing.
  3. gliderman
    gliderman Active Member
    751
    225
    And you want the oil to go through the filter. The filter system has a high pressure bypass already. Not sure how this bypass system you are looking at works on a Prius.
  4. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    My thoughts exactly. There's no mention of an oil cooler, oil filter adapter, etc. Besides, the ICE on the Prius is already a detuned gasoline engine (Atkinson cycle), which isn't running all the time, and is assisted by an electric motor. Toyota has already approved an extended oil change interval of 10,000 miles using 0w-20 weight synthetic oil, so how much longer one would want to extend this is beyond me. :rolleyes:
  5. LTZR1
    LTZR1 Member
    134
    31
    Midwest
  6. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    The filter itself has NO bypass. It's a cartridge filter. The bypass is built into the filter system located at the top of the the filter cartridge housing mount.
  7. gliderman
    751
    225
    Sorry, I should have said filter system. Yes, I know the filter does not have a bypass, thanks for the correction.
  8. AlanInAustin
    16
    KaleCoAuto.com is a website of fictional car parts & accessories. In there you'll find things like a string of tire beads, 710 caps, seasonal tire air, car to tank conversion kit, salad shooter spinning rims, etc.
    I was aiming for a laugh -- I didn't think anyone would take this seriously! ;)
  9. gliderman
    751
    225
    People on this forum rely on the information of others with a certain amount of trust and confidence. You got your laugh, enjoy it. But you may have lost some of the confidence and trust of others here with your prank.
    Good luck!
  10. xliderider
    8,140
    3,278
    Honolulu, HI
    Says the boy who cried "wolf"...
    Yeah, you got us pretty good. :p
  11. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
    I bought a bucket of steam from that company, was pretty good, would recommend it.
    I also got a great deal on 5 cases of dehydrated water.
    AlanInAustin -- good one.
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Sadly we deal in a great many 'scam' and 'bunk' that is not in jest. From K&N filters and 'aero' body kits that are less aerodynamic than the stock body, to real wastes of money like hydrogen generators and 12 volt electric turbrochargers. It is hard to put a lower limit on what folks will believe.
    My favorite fake store:VillainSource -- formerly VillainSupply
