2010 Prius Gen C - Hybrid Battery Advice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lynde Lu, Jul 28, 2019.
  1. Lynde Lu
    Lynde Lu New Member
    23
    Austin, TX
    Seeking advice on if my hybrid battery is going bad. I have a 2010 with 127k miles, owed it for 4 years with absolutely no issues. While I was driving through the car wash in neutral yesterday my prius started beeping stating the battery was too low and needed to be shifted back to the park position. I'm about to drive 1000+ miles from AZ to TX in about two months and worried my hybrid battery may need to be replaced before the big trip. I'm a little concerned about taking into the dealership since I don't find the dealership here to be entirely trustworthy. Any advice on my next steps or things to keep an eye out for to truly know if my hybrid battery is failing?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Should be fine just make sure your batt is full with ac off when going through car wash
    Lynde Lu likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You don’t want to be on neutral at anytime because your hv battery doesn’t get charged. Once your in neutral and with ac on in the car wash, battery will run low and car won’t be able to charge the battery until you put it back to neutral or drive. Now that the battery has aged, you want to go to car washes that required you to stay on park the entire time.
  4. schmuber
    schmuber Member
    115
    85
    Georgia
    Typical problem with tunnel washes, nothing to worry about… unless you're in a tunnel and your car is throwing a battery tantrum. We all usually let it happen once, then never do it again.
    ^ what he said.
  5. bisco
    52,863
    there is no such thing as a 2010 prius gen C
    Don Morton and Grit like this.
  6. Lynde Lu
    Lynde Lu New Member
    23
    Austin, TX
    Sorry, my first thread, still trying to get the hang of it.
    Raytheeagle and bisco like this.
  7. Lynde Lu
    Lynde Lu New Member
    23
    Austin, TX
    Oh I meant gen 3! Wow, I was really struggling yesterday, haha. Thank you for pointing that out!
    CR94 and bisco like this.
  8. Don Morton
    Don Morton New Member
    South Carolina
    "C" = "3" - same thing.
  9. bisco
    52,863
    gotcha, gen D = 4?
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Must be a Texas thing:whistle:.
    We definitely don’t understand (y).
