2010 Prius Gen3 MAF Sensor Wiring - Solved
Discussion in 'Gen 3 Prius Main Forum' started by TL Phillips, Jun 13, 2022.
  1. TL Phillips
    TL Phillips New Member
    Saturday Night I hit a deer on the highway and when it damaged the front hood three wires in the MAF sensor pig tail connector was pulled out because the hood stand arm came loose and dropped on the wires and the connector.
    I need the 2010 Prius 1.8L color code pattern to install a new pig tail for the mass Air Flow Sensor.
    It has 5 wires from the wiring harness to the connector.
    The White and Black wires are still connected just don't know were the other three wires go?
    If you look at the image of the pig tail plug three wires are disconnected and two are connected. The replacement plug I have all the wires are the same color.
    Does any one have the color wiring diagram that shows what wire goes were via color of the wires?
    Or a picture of a 2010 Prius 1.8L MAP sensor showing the wires with the same color wires going into the connector would help also.
    I have search the internet even tried google lens to find an image matching the wire colors and diagram search with no luck. Current Plug Wires.png DeerDamage.png
    Thank you in advance.
  2. TL Phillips
    Posting this because on another forum I got a reply via image of 2010 Prius 1.8 MAF sensor plug wires.
    Posting just incase same thing happens to someone else. Matter closed!
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
  4. Mendel Leisk
    42,364
    Yeah, questions like this, all that is required is for someone to go pop the hood, take a pic and post it. One of the simplest/best features of this site. (y)
    mollymudpie likes this.
  5. tony_2018
    tony_2018 Member
    227
    68
    yeah, I would've but haven't been on here much. Been out searching for some decent rims
