2010 Prius goes into Ready mode but engine won't start
Discussion in 'Gen 3 Prius Technical Discussion' started by andy song, Aug 28, 2024.
  1. andy song
    andy song Junior Member
    As the title says I can get my 2010 Prius into Ready mode. The car moves under electrical power
    But the ICE never starts
    It was driving fine the day before and today this happens
    I took a volt meter and check all the voltages of the coil packs and the injectors and the harness do not show any voltage to those items
    I have switched out the crank position sensor with a new aftermarket one from ebay
    I also check the fuses and cannot find any blown fuses
    Has anyone encountered this issue?
    52,878
    any trouble lights?
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,693
    1,076
    South Central PA, USA
    Can you please explain why you replaced the crank position sensor?
    When did you replace it?
  4. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    You need to check for codes. Also, post #3
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    There can be many reasons why the petrol engine does not turn on.
    As a rule, a malfunction icon appears on the dashboard and you can read the problem code with a scanner.
    Can you attach a photo of the dashboard?
