2010 Prius Grill Blocking strategy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ken1784, May 31, 2009.
  1. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    He has a Plug-in Prius. The ICE can remain off at speeds up to 62mph in the right weather conditions or when coaxed to do so by the driver.
  2. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Pump your tires up to sidewall max for the front and sidewall max - 2 or 3 for the rear and see if that doesn't change.
  3. markabele
    5,084
    1,782
    Nebraska
    Hopefully you mean that if it is extremely cold or you accelerate way too fast then the ICE may come on before you reach 62.
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Well, I think so. Did you read my response before firing off yours? :p
  5. gliderman
    gliderman Active Member
    751
    225
    My tires are pumped to max all the time. I guess my engine will just stay on and burns gas at anything over about 20mph.
  6. markabele
    5,084
    1,782
    Nebraska
    You made it sound like it has to be perfect weather and you used the word coax. To me, coax sounds like you have to baby it to get it up there.
  7. markabele
    5,084
    1,782
    Nebraska
    Have you watched the great video of hypermiling on these forums?
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Those videos provided examples of what the ODB-II devices can deliver. My best filmed footage is with the 2012 PHV, since I've had lots of opportunity to refine technique. For examples from my 2010, you have to page back to older videos.
    AS for your ICE not turning off at higher speeds, it should. 46 mph is the upper limit for the 2010, which I saw every time I drove. Simply slowing down after warm-up is complete will trigger the shut off. Notice the drive through town on this video with my 2010:
  9. gliderman
    751
    225
    Yes.
  10. gliderman
    751
    225
    I will watch that display when I drive today. I have been watching the SGII and the RPM is always displaying the low 900's when I think the ICE should be off. SO I will check the display and see if there is a disparity between the SGII and the Prius display. Thanks!
  11. markabele
    5,084
    1,782
    Nebraska
    I guess I still don't understand. Is the problem that you are not sure when the ICE is turning off or not?
  12. gliderman
    751
    225
    According to the SGII the ICE is not turning off until I get under about 20mph or put on the brake.
    If the ICE is supposed to turn off when I back off the gas pedal under 46mph, (given sufficient battery charge and no power demand) then something is not right.
  13. markabele
    5,084
    1,782
    Nebraska
    The easiest way to tell if the ICE is running or not on the 2010...
    If you are under 46 mph and are giving it just a little bit of acceleration (but not enough to go over the half way line) and still see your instantaneous MPG at 100+ then you know the ICE is off.
  14. gliderman
    751
    225
    Thanks! I will keep an eye on the instant mpg too.
  15. john1701a
    12,840
    5,312
    58
    The system must be warmed up for the engine to shut off.
    With the 2010, that means coolant must reach 145°F before that will happen.
    In ECO mode, it will remain off until the temp drops below 114°F or you request power beyond the GREEN range or you exceed 46 mph.
  16. gliderman
    751
    225
    Yes, got that! Thanks!
  17. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    If the weather is less than ideal, and you don't coax it, the ICE will come on. In warm weather (above 65 F), you can almost floor it in EV and the ICE stays off. In very cold temps (30 F and below), depressing the accelerator beyond 2/3 on the HSI will almost always fire the ICE. Certainly you must be seeing this behavior in NE with the cold weather. I see it here and we've only gone below 32 F three or four times this season.
  18. gliderman
    751
    225
    My observation today: SGII shows ICE RPM's even with ICE off, but not all the time. ICE off state on MFD to me means no ICE power going to drive train or battery, and instantaneous MPG showing 100+.
    So, now I dont know what to think of the SGII. Except it is wrong, unless the ICE is turning without sending power to the drive or generating power for the battery.
  19. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The RPM gauge in Scan Gauge will register ~960 when it's turning to prevent MG overspeed. It's not using any fuel but just sort of free-wheeling.
    Robert Holt and snead_c like this.
  20. gliderman
    751
    225
    Good to know! Thanks!
