2010 Prius Grill Blocking strategy
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ken1784, May 31, 2009.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I honestly don't know, it probably does because it's not going to get to cold. I do remember reading that the inverter coolant system had no thermostat.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i believe we have determined that the coolant system for the inverter has no limiter (thermostat)
    since it has no thermostat, its probably not monitored
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The NCF document mentions that the inverter water pump is three speed and the coolant temperature is monitored.
    Ken@Japan
    9 people like this.
  4. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    thanks for info Ken. with that many monitors, it seems strange that no one has cracked the code yet. inverter temp monitoring and safe levels has had a ton of airplay here.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Nice! 3-Stage Inverter Coolant pump. Mine is only one speed.
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    oh, so the 2004-09 were single speed?
  7. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I checked and confirmed the inverter coolant pump is relay (ON-OFF) driven shown in the JP Gen2 maintenance manual, so it is single speed.
    Of course, the inverter coolant temperature is monitored on the Gen2 too.
    Then, the cooling fan will be activated when it detects high temperature.
    Then, an explanation mark will be displayed when the temperature becomes too hot.
    Ken@Japan
    2 people like this.
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Ken,
    I thought the inverter coolant pump runs all the time. As soon as the car is in "Ready", the pump comes on.
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Yes. The inverter coolant pump relay is ON as soon as the car is in "Ready".
    So, it is single speed, no variable speed mechanism.
    Ken@Japan
  10. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    What temperature sensor could trigger the exclamation mark (MG1, MG2, Inverter, Engine)?
    Could we trust the exclamation mark to know if we are putting the inverter at risk with the upper grille fully blocked?
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    There is no temperature threshold description found on the US NCF and JP maintenance documents.
    I believe we can trust the exclamation function threshold.
    Before the mark, the cooling fan works hard, and we'll have to consume the extra electric energy. :mad:
    Ken@Japan
    2 people like this.
  12. tumbleweed
    4,067
    692
    Eastern Oregon
    You don't need a template, or anything else, except some 1/2 inch pipe insulation (about $4 at Ace Hardware) and a pair of scissors. I cut mine a little long and then went back and trimmed the ends a bit to get a good fit, it doesn't need to be exact anyway.
    You use 4 pieces for a 100% block of the lower grill, one piece for each of the 4 openings. No need to tie it in just pinch the insulation together and put it in the slots, it expands and holds itself in the opening.
  13. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    It took me about 10 minutes to install foam insulation I had in the basement to the lower grille. I "borrowed" some tie wraps from work. The foam color blends in nicely with the winter gray color.
    Tools needed---scizzors.
    materials----2 pieces of 3/8" foam insulation(it's what I had in the house) and 9 tie wraps.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I was going to do the same thing and make a more or less permanent fixture. There is a place in NC that will make them if they get someone to drop by their 2010 for measurements/fittings. I may still try something like that in the future but for now I use the tubing.
  15. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    I don't recall seeing this mentioned earlier, but blocking the lower intake makes the vehicle interior quieter, at least if one uses foam pipe insulation. Nice side effect.
  16. uglymuddah
    uglymuddah Junior Member
    24
    The Netherlands
    Thnx Ken, I'm have my grill blocked on my Gen3, according to your table of course. Do you have a similar table and piccy for the Gen2 as a friend of mine owns a Gen2 and is interested. Can I safely tell him it's ok to block the upper grill, not only in winter but also during summer? Leaving the lower grill open all the time?
    Thnx a Prius fan from Holland (Europe) :rockon:
  17. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Thank you!
    following is my personal recommendation for Gen2.
    temp in Celsius temp in Fahrenheit lower blocking % upper blocking %
    1 below 5 below 41 90 100
    2 5 - 18 41 - 64 80 100
    3 18 - 30 64 - 86 60 100
    4 above 30 above 86 40 100
    note: except long uphill or over 70 mph cruising
    Ken@Japan
    4 people like this.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  19. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    It's almost as same as summer setting on my suggestion. :)
    Ken@Japan
  20. uglymuddah
    24
    The Netherlands
    I ordered this OBDKey today for 165 dollar. It sends all data through Bluetooth to my cellphone (HTC cruise). Hope it is as good as the Scangauges or Xgauges u guys have.
    OBDKey :: OBD Bluetooth
    I've got the rest of forummembers in the Dutch forum fired up now, so Ken another thnx 2 U:cheer2:
