2010 Prius, Head gasket replacement. Re-ring pistons/ hone cylinders without pulling engine?
Discussion in 'Gen 3 Prius Technical Discussion' started by RobRig, Aug 8, 2021.
  1. RobRig
    RobRig Junior Member
    Richmond, VA
    My 2010 Prius may need a head gasket replacement; I'm not going into details, I can troubleshoot that, I've done heads before, just not on a Prius.
    It also burns about 1 quart of oil every 800 miles and I'm thinking of re-ringing and honing the cylinders while I've got the head off, if indeed I need to replace a head gasket.
    Is it possible to remove the oil pan and pistons with the engine still in the car or would the engine need to be pulled?
    How hard is it to pull the engine?
    If the head gasket is OK and I don't need to pull the head, is it possible to re-ring the pistons / hone cylinders from the bottom without pulling the head? Can this be done? Has anybody tried it?
    If it can be done without removal, any tips or suggestions?
    Any recommendations for preferred gasket sets?
    If indeed I need to replace a head gasket, I'm considering starting on this project in the next few weeks.
    Krall likes this.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The labor required to pull the engine and re-ring it correctly is less then the labor you will waste trying to re-ring it from the bottom, only to have to pull the engine anyway. It is possible to have the engine out by itself from the top in just a few hours. Pull the engine and rebuild it now, before the head gasket fails and the engine hydro-locks or hand grenades.
  3. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    The oil pan has two parts. And to remove the 2nd part to get to the connecting rods, you must
    remove the engine.
    The pistons are installed and removed from the top. The crankshaft is in the way that's
    why you can't remove them from the bottom.
    I am not sure if you can still get the rings because they updated the rings and pistons late 2014 it is believed.
    I imagine you could remove the pistons with rods and soak them in solvent to remove the carbon build up,
    thus freeing the rings. Will the rings be as "springy" as when new? Probably not. But you might be able to
    go another 100,000 or 200,000 miles on it before they get gummed up again. Depending on how often you
    change the oil and if you use any engine cleaner.
    But it seem to me that if you are going to go that far, spend the little extra money and get the 2015 model
    pistons and rings. I believe you have to heat up the piston/rod assembly to remove the wrist pin. Though I
    seem to remember 1 or 2 people saying they didn't have to do that. So I do not know.
    Toyota has an engine rebuilt gasket set. It's probably the best one out there. But there are others.
    RobRig, Krall and Mendel Leisk like this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,045
    6,922
    Texas Hill Country
    Pull the engine, rebuild including the head, clean everything and install the Toyota gasket set. The head and intake will be carboned up and you will want new valve seals as they can contribute to oil consumption. A 2012-15 intake would be an improvement as well as a catch can. Then change the oil at 1k miles and every 5k thereafter. Another 100k-150k miles should be the result. Excluding the brake booster and batteries at a minimum. Some would change the radiator fans while the access was good.
    RobRig likes this.
  5. Mendel Leisk
    42,301
    I’d second @ASRDogman : if you’re doing the rings, best to swap to the revised pistons and rings. They were introduced partway through model year 2014. The pistons have to change too because the revised rings are not compatible with the old pistons. The revision was apparently to reduce oil consumption problems that started cropping up with the older (lower friction?) rings.
    attached TSB has lots of info on the rebuild, and all the part no’s.
    johnHRP, tony_2018 and ASRDogman like this.
  6. rjparker
    11,045
    6,922
    Texas Hill Country
    The best advice is in a red box several times throughout the procedure. Plus it applies to major omissions like the head in an older engine.
  7. RobRig
    Richmond, VA
    Thanks guys. That's exactly the kind of feedback I was looking for.
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Depends on if the owner is a DIY that can clean intake manifolds. The newer intake design may not be an improvement. The old design has straight passages (instead of the tournament design) and is easier to clean with pipe brushes.
    I agree that an OCC is useful for improving performance and extending engine life.
    xliderider and Mendel Leisk like this.
  9. tony_2018
    tony_2018 Member
    227
    68
    Pull the engine
  10. Krall
    Krall Member
    125
    37
    NY
    So the oil consumption is from carbon build up on the pistons and not blow by past the rings?
  11. rjparker
    11,045
    6,922
    Texas Hill Country
    As I understand the problem, the rings freeze up and cause uneven wear on the cylinder walls. That causes oil to get into the cylinder and increased pressure pushes oil through the pcv system. One Toyota mechanic suggests overfilling oil aggravates the condition. Once wear is excessive, rehoning won't do it. So the mechanic or ideally the engine rebuilding machine shop has to carefully inspect the cylinder walls. If uneven wear is present, the block must be replaced. While Toyota initially did replace pistons and rings under warranty for 2010-14 excessive wear victims, their practice now is to find a better engine or use a new short block.
    Remember Toyota was providing warranty piston and rings on engines with less than 60,000 miles, not engines with two or three times that number. In reality few engines start burning oil excessively until well past 100,000 miles. My 2012 started around 150,000. Given that most people don't repair it immediately, excessive blowby carbons up everything through the pcv and egr systems, followed by clogged egrs and or blown head gaskets. Around here the discussion is often "what came first, the chicken or the egg?" Doesn't matter if your chicken is gone.
    In a similar manner, a dealer head gasket job for these engines is usually not recommended because the job could easily escalate to a new short block rebuild, depending on conditions found after the engine tear down. Many dealers would rather swap a "low" mile used engine before committing to a head gasket job on these engines. As a result most customers find independent shops for head gaskets or rebuilds. With good results if the mechanic verifies each step of the way.
    #11 rjparker, Oct 6, 2021
  12. Krall
    Krall Member
    125
    37
    NY
    Thank you for all your info!
    I'll just assume with me and 280k with oil burning issues and a blown HG that my cylinder walls are unevenly warn and a simple de-carbon soak for my piston and rings aren't going to be a miracle cure :)
  13. ASRDogman
    8,053
    4,083
    Assume???? A dangerous practice! :eek::rolleyes:
    There is a special tool to measure the cylinder walls to determine if they are still round and not oval.
    Not sure what it would cost, but a machine shop could do that.
    And if needed they could bore it out and you'd have to use the next size pistons and rings,
    if Toyota, or aftermarket, make them.
    Unless you've over heated the engine, the cylinder walls are likely fine.
    Krall likes this.
  14. Krall
    Krall Member
    125
    37
    NY
    lol is that you Miss Goodknow my 3rd grade teacher? :D
    I guess assume was a poor choice of words. For whatever reason around here I'm limited by mechanics that will even take on that kind of work. Plus most of them are backed up for months. I only saw the overheat light once a couple of weeks ago for a second. After that I added more fluid that was lost. I haven't really driven the car at all since for fear of bending a rod.
  15. RobRig
    Richmond, VA
    FOLLOW UP:
    I decided on pulling the engine, replacing the head gasket, resealing and lapping the valves, replacing the rings and honing the cylinders.
    The oil control rings were packed with shit, so much so, at first I didn't think there were any oil passages in the bottom ring. I soaked the rings in straight soap for a day or so, and when rinsed them and blew them out I could see the ridiculously small oil control holes in the OC rings. The piston itself has 3 small holes on each side in the OC ring groove, if I recall correctly just above the piston pin area.
    As far as replacing the pistons with new ones, I just cleaned the pistons while they were removed. I had found a video on YouTube where a guy in Euro ordered the new Toyota pistons and rings and did a comparison right out of the new box with the original pistons/ rings. He didn't see any differences between the old VS new that would solve oil consumption issues, neither did I; I'm thinking the new ring and piston part numbers from Toyota are mental smoke and mirrors to make the customer think they've fixed a problem.
    I ordered an engine gasket kit, but separate kit for rings and separate set of head bolts. It was cheaper that way VS getting a ring/ gaskets/ bolts as a single kit.
    Got a brand new, never used hoist for $150 locally (Harbor Freight is $250), an engine leveler on Amazon for about $35 (that was a life saver and worth the money), and a new engine stand from Harbor Freight for $70. Started pulling the engine Saturday around 9 am, by 6 pm it was on the engine stand in my basement ready to tear down.
    Tear down, inspection, and rebuild took place over the next few weeks on evenings after work.
    I think install would be about a day, except after bolting up engine to tranny and eng mount, getting most of the externals back on the engine I found I was missing a metal angle bracket the holds the wire harness above the transmission just above the engine mating flange. When I couldn't find it under the engine, on the frame, or on the ground I began to get concerned that it was in the transmission belt housing area.
    I had to disconnect/ remove a bunch of stuff that I already put back on, reattach the hoist, unbolt the mount and engine from the transmission and pull the engine away from the transmission, and no shit, the metal bracket was knocked off and laying in the bottom of the bell housing waiting to get picked up and trash out everything inside that area.
    Basically I had the engine in and out twice, so at this point I'm guessing it should've only been a day to put it in.
    I was surprised at how easy it was to strip down and get in and out. My biggest cost was equipment to pull it, followed by time and materials.
    Unfortunately I still get oil collecting in the bottom of my intake manifold after all that work, but coolant tank doesn't have to be re-topped every week now. I'm working on a OCC installation next.
    #15 RobRig, Dec 13, 2021
  16. ASRDogman
    8,053
    4,083
    The pistons and ring are different for the 2015.
    Someone ordered just the new rings. But they were to big to fit on the 2010-13 pistons.
    I believe the grooves in the updated pistons are wider, and the top is designed differently.
    Also, the oil holes are larger. At least that is what he was saying, and he ordered the new pistons...
    Bummer about the bracket! I hate crap like that, so simple, but deadly!
    I'm glad you were able to get it all back together and running. I hope it lasts hundreds of thousands of miles!
    Why didn't you install and OCC when you had the engine out? That would have kept most of the
    oil out of intake, and engine. Just wondering.
  17. rjparker
    11,045
    6,922
    Texas Hill Country
  18. Mendel Leisk
    42,301
    That’s a saga!
    Never done anything like this, but it occurs to me, if you’ve got the older pistons, just swapping in a new set of (old style) rings, you’d have an easier job, and still be good for at least 100k.
    also, any thoughts on drilling out the oil passages on the pistons, slightly enlarge them?
  19. ASRDogman
    8,053
    4,083
    If you drill the pistons, you'll to take them off, and balance them.
    In theory, they should all be even if you use the same drill size for all.
  20. OptimusPriustus
    OptimusPriustus Active Member
    337
    143
    Finland
    One might think bigger holes equal less resistance for piston movement so..why Toyota made them too small? Just asking. They were not born yesterday
