2010 prius high temp light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ed480, Jul 10, 2023.
  1. Ed480
    Ed480 Junior Member
    Mesa
    Hello hope I can get some help to figure out whats going on. I have a 2010 prius and going up hill twice at the same exact spot my high temp light came on for about 3-5minutes and turned off so I did some research and decide to replace my water pump and thermostat. I flush the cooling system and filled it up with new coolant. Its still doing the same thing going up hills. I live in Arizona so its 100f + now outside. Any idea why it’s doing this?
  2. PriusCamper
    PriusCamper Senior Member
    13,168
    5,323
    Pacific Northwest, USA
    Got any warning lights/error codes? If you get a sucking sound when you open up coolant resevoir it's early stage of head gasket failure and you could get a year or two more before repair if you avoid long drives and the worst of the hot weather.
    Also cleaning out the EGR system will help the engine run cooler.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    air in cooling system?
  4. Tombukt2
    Tombukt2 Senior Member
    13,548
    2,440
    Durham NC
    Water pump not working or water pump is to the point where the impeller has cracked plastic on its coating It's rubbing the mag drive portion of the pump which is the well that the impeller turns in and it's working very erratically You can lower the coolant pull the pump off set it up on the car get in the car with the proper software you can call up the water pump and turn it on and you'll be able to see it chunking spinning stopping spinning stopping turning a little stopping turning a little stopping turn it off with the software turn the car off try and spin the pump with one finger It should go relatively smoothly
  5. Brian1954
    Brian1954 Senior Member
    2,477
    990
    South Central PA, USA
    How many miles on the car?
    What water pump and thermostat did you buy?
  6. BiomedO1
    BiomedO1 Senior Member
    4,314
    2,264
    Left Coast
    check your radiator with an IR temperature gun, cold or hot spots indicates a clog. Also check to see if your electronic fans are turning-on.
    If anyone has ever put 'stop leak' or 'head gasket repair' into the coolant system - it's probably clogged and/or gummed up.
    BrianStranded and Brian1954 like this.
  7. Tideland Prius
    16,629
    @Ed480 Sorry I messed up your posts. Could you resend the replies?
  8. Ed480
    Ed480 Junior Member
    Mesa
    No codes nothing. I don’t know if EGR ever been cleaned I just got the vehicle few weeks ago.
    Electronic fans turn on I check the radiator with IR gun there is no cold or hot spot.
    It has 260k and burns some oil.
    I bought them off Amazon and both them had lots of good reviews. I actually just change the rotor in the pump but the old one wasn’t expanded or anything. I was driving yesterday again going uphill it came on for a few minutes so I pull over and this time I notice it splash out some coolant from the tank. Before I change the thermostat and the water pump rotor it didn’t do that when the light would come on.
    I did no problem. Update so I took the EGR out and it was pretty dirty in there so I clean it and put it back.
    #8 Ed480, Jul 12, 2023
    Tideland Prius likes this.
  9. Brian1954
    2,477
    990
    So you do not know the maintenance history for the car.
    Is the engine in the car the original? Hopefully, a Gen 4 engine was not installed, because there are many reports of a Gen 4 engine overheating in a Gen 3 car.
    Make sure that air can flow through the radiator. It could have sand, dirt, leaves, or debris in the radiator fins, which is not letting the full flow of air.
    The previous owner(s) of the car may have had a bad head gasket and used stop leak in the engine coolant system. The original engine water pump may have been replaced with a cheap water pump. When you replace the water pump rotor, did you notice if "Toyota" was cast on the pump.
    My guess is that reduced water flow is causing the overheating. This could be caused by restrictions inside the radiator (stop leak), or the water pump is not spinning fast enough. If you have ruled everything else out, I would buy a new OEM water pump and install it.
  10. Ed480
    Ed480 Junior Member
    Mesa
    No the pump was afternarket but looked new but since I had it out I out in the new rotor.
  11. Ed480
    Ed480 Junior Member
    Mesa
  12. Brian1954
    2,477
    990
    Replace that aftermarket pump with an OEM water pump purchased from a dealership.
  13. Ed480
    Ed480 Junior Member
    Mesa
    Yes but I would like to make sure I am bleeding the system right before I do that because what if thats the problem?
  14. Brian1954
    2,477
    990
    The air bleeding procedure has been discussed already in this forum. Do a search to find it.
  15. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    Man you are giving terrible advice.
    The amazon waterpump is fine, its probably an Aisin pump which is the same as factory. Either way lets not just throw parts at the car dude.
    Check the car for error codes first then report back. My car overheated ultimately because of a headgasket failure but intermittently due to using a stop leak that clogged up various parts, including radiator, overflow tank and thermostat.
    CHECK FOR CODES WITH A SCANNER
  16. Ed480
    Ed480 Junior Member
    Mesa
    There are no codes. I bleed the system yesterday so I am hoping it fixes the problem.
  17. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    So......now it is 13 days later......and it appears that the problem is not fixed.
    But that should have been posted HERE instead of in a new thread.
    This could be a simple as a failed pressure cap or a radiator clogged with dirt or bugs
    in the external fins.
    It sounds to me like it is time to let a shop test it and let you know what is wrong.
  18. Ed480
    Ed480 Junior Member
    Mesa
    I replaced the pressure cap
  19. BiomedO1
    4,314
    2,264
    Left Coast
    If your sure you have adequate coolant flow, Check the plastic coolant diverter valve; if so equipped and thermostat.
    If it was me and you verified that everything above is working correctly; I'd go after the radiator itself; since you know stop leak was used. Partial clog, restricting coolant flow (effectively shrinking the size of the radiator from within)
    That's what 'stop leak' does, coats the internal surfaces to plug a leak - much like 'slime' for tires
    Sorry; That was Brian that mentioned stop leak in post #9.
    #19 BiomedO1, Jul 28, 2023
