2010 Prius Horns not Working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eric Smallwood, Dec 20, 2025.
  1. Eric Smallwood
    Eric Smallwood Junior Member
    Lawrenceburg, IN
    My horns are not working even when I hit the emergency button on my key fob. All of the lights flash, no horn. All of the buttons are working on the steering wheel and no grinding sound when turning the wheel. ?????
    2010 Prius 184K miles.
    #1 Eric Smallwood, Dec 20, 2025
  2. Brian1954
    Brian1954 Senior Member
    2,553
    1,010
    South Central PA, USA
    Does the horn work when you activate it on the steering wheel?
    You also created a different thread ( https://priuschat.com/index.php?posts/3586635) about the rear defroster not working. They could be related. Did you check the appropriate fuses?
  3. Eric Smallwood
    Lawrenceburg, IN
    No fuse for the horn according to the manual. There is a fuse for the heaters in the side mirrors and it is good.
  4. Eric Smallwood
    Lawrenceburg, IN
    Determined both wires were yanked out of the horns. Spliced in a new wire with female spade fittings and it works perfectly!
    Brian1954 likes this.
  5. ChapmanF
    18,873
