2010 Prius HVAC Issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DailyPrius10, Dec 12, 2021.
  1. DailyPrius10
    DailyPrius10 New Member
    Upstate NY
    My 2010 prius had a mouse nest inside cabin under dash and inside the HVAC box. After many hours I have the HVAC system cleaned out and operating as it should except for one of the servo motors. The air mix servo motor seems to be rotating the wrong direction? This motor is accessible from the passenger side, I can test the movement thru an OBD connection and see its commanded position and actual position. However based on what I see it seems the motor is moving the internal HVAC gate the wrong direction. The motor spins counter clock wise when going from low to high, moving the gate all the way forward blocking the heater core therefore getting no hot air? Does anyone have a gen3 to verify the rotation of that servo motor?
    Thanks,
    bryan
  2. Pdaddy
    Pdaddy Member
    160
    49
    I hope you can figure this out. We had to replace the entire system when the blend door failed sans mice.
    SM-G960U ?
  3. ChapmanF
    18,918
    This is a case where I would want to have Techstream open so I could watch the commanded and current position numbers for the mix door.
  4. DailyPrius10
    Upstate NY
    I can see the command and current position with my obd adapter, not techstream. The servo motor seems to going to where it is supposed to based on readouts. I am confused because when the heater is on high the interval hvac gate is blocking the heater core, the gate is all the way forward in HVAC box. When servo motor is on the warmest air comes out when I set the temp to 65F.
    The other thing I cannot figure out is my temperature setting does not match my OBD readout, at high the OBD reads 112.5 F and at low reads 92.5F. Is there a way to reset or caliprate that setting? Is my control unit shot?
    it was 8 F outside this morning, I have the air mix gate manually set (servo motor off) to where I think it forces all the air through the heater core. The warmest I could get the car on my 30 minute commute was 62F, the coolant temp runs around 185-190F. I previously verified flow thru heater core with temps matching collate temp. I have flushed core and exhaust flow with coolant and thermostat change.
    Any advice would be appreciated.
