2010 Prius Hybrid Battery Dead
Discussion in 'Gen 3 Prius Main Forum' started by lothar zogg, Sep 3, 2017.
  1. lothar zogg
    lothar zogg Junior Member
    georgia
    Hello - I've had my 2010 Prius for six years. I've loved the car's functionality. About a month ago, the same day the odometer hit 150,000 miles, after a slight hesitation in acceleration, the yellow warning triangle and check engine light came on. Took the car to the dealership the next day and they told me I needed a new hybrid battery. After the shock wore off, I started doing research on battery replacement. In the meantime, I've been driving the car with the warning lights on and getting from 30-35 mpg. Since my Georgia vehicle inspection is due in September and a vehicle in Georgia can't pass the emissions test with a lit check engine light, my hand has been forced - I'll have to bite the bullet and either repair or replace the battery this month.
    I've pretty much decided that since I intend to keep the car another 3 years, I'm going to get the battery replaced with a new Toyota hybrid OEM battery. Cost somewhere in the $3-4K range. Reason for this decision - I'm too poor to buy cheap. In other words, this repair needs to last, and after looking at the refurbished battery options, I don't trust them to last. Any comments on my decision will be read with interest.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Buying a new pack is your best option by far if you plan on keeping your Prius for another 3 years provided you have taken good care of it. Cars these days can last 20 years and more. Definitely buy a new pack and do it soon. You shouldn't be driving with a known bad pack, it could catch on fire if one of the 28 modules explodes - that would ruin your day and might ruin your Prius too.
    CNYhybrid and lothar zogg like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Did the dealer give you a print out of the codes? Have you cleaned the HV Battery fan? What other maintenance have you done? Does the battery show any signs of quickly draining and charging on the HSI display?
    Keep us posted (y).
    Princer and lothar zogg like this.
  4. lothar zogg
    georgia
    Thanks for your response. No, I didn't ask for the codes, and I haven't cleaned the HV Battery fan. Only maintenance I do is oil changes. The draning and charging on the display seems normal to me, even after warning lights came on. Would cleaning the fan make any difference at this point?
    Raytheeagle likes this.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    And have you tried resetting the light (clearing the code) and making sure that it comes on again? Perhaps it was a fluke since you have no outward symptoms? Also, if there is a lag between reset and it coming on again, that could get you through inspection. Knowing the precise codes would help a lot.
    Princer likes this.
  6. lothar zogg
    georgia
    Thanks for your response. The dealer said there were dead cells in the battery. I might be able to get the codes when they open on Tuesday. I don't know how to reset the codes. Since the warning lights came on, I have definately not had use of the hybrid battery. Maybe it automitcally is disconnected from the electric motor when the warning lights come on - not sure.
  7. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    I would ask for the codes to confirm the diagnosis;). This will help determine the root cause or what is currently ailing your Prius.
    My understanding is if the cells are out of balance too far, the car will not run. So if you are running still, that is a good sign:).
    Do you hear the fan running in the back?
    My first step would be to clean the fan and then disconnect the 12v battery to clear the codes and see if they return. This is all while waiting for the codes read by the dealer report;).
    Keep us posted (y).
    #7 Raytheeagle, Sep 3, 2017
    Princer likes this.
  8. jadziasman
    1,355
    488
    District 6
    13V battery? That's odd.
  9. bisco
    52,694
    is the 12v battery original?
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    A third gen Prius traction battery will not burn. There will be no fire. NiMH batteries contain no flammable parts.
    Your battery is still connected as your gas engine starts. It is used to start the engine, run the A/C, etc. The Prius won't work at all if the traction battery is disconnected or has deteriorated too far. For example, the answer to the question "can I still drive my Prius without the traction battery?" is NO. The engine won't start. Further, the drive train ("transmission") won't work either as it needs the high voltage to generate the magnetic fields that "connect" the input to the output.
    If you feel $3-$4k is reasonable for 3 years of use go for it. You won't get a lot when you eventually sell the car or trade it but you will get more if it's running properly. Oh, and with a new Toyota traction battery you get a one year warranty on it.
  11. lothar zogg
    georgia
  12. lothar zogg
    georgia
    Update on my dead traction battery. I read somewhere on PriusChat that the Toyota factory sometimes chips in on the costs of repairs to generate goodwill, so I asked my Toyota dealer if the would check with Toyota on a goodwill repair. I had to wait a month, but in the end Toyota paid for a new traction battery. I had no out of pocket costs. This was the like winning the lottery for me. Lesson learned - always ask. You never know what might happen.
    m.wynn, Princer, orenji and 10 others like this.
  13. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Congrats. Can I ask what work you had done at Toyota dealerships, prior to receiving the good will credit?
    Princer likes this.
  14. lothar zogg
    georgia
    I had some front brake work done at this dealership and lots of oil changes and an alignment. I also own two other Prius' which I also have serviced at Toyota.
  15. bisco
    52,694
    congrats! and good on toyota!(y) (especially considering you're 50,000 miles over the warranty.)
    Princer likes this.
  16. MelonPrius
    839
    516
    Nevada
    Seems like it's consistent that good will assistance towards hybrid batteries is based on whether or not the car owner had maintenance done at the Toyota dealership. That doesn't bode well for me.
    m.wynn and Raytheeagle like this.
  17. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Think of all the money you are saving by not going there ;).
    Set it aside and I bet it is equivalent or positive (y).
    m.wynn likes this.
  18. FireCob
    FireCob New Member
    Colorado
    That's incredibly awesome. Congrats man, I'm coming up on 120k miles and I'm a bit paranoid of my battery crapping out on me at any moment...
    Princer likes this.
  19. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    A cheaper option is to replace just the defected modules . These could be found in used parts stores .
  20. lothar zogg
    georgia
    I agree the dealership can be expensive so I always do my due diligence on prices. For oil changes, I like to use synthetic oil, which the dealership charges about $65 - too much for me, but they also send out coupons on a regular basis, so I wait for those and usually net about $40 for the oil change. Same for other routine maintenance, wait for the coupon. For tires, I've always found Costco can't be beat, but I usually let the dealership quote me just in case they can get close.
