2010 Prius Hybrid Battery ? P0A80
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rapptorr, Aug 31, 2022.
  1. rapptorr
    rapptorr New Member
    Harrington Wa
    Hello all, having issues with the hybrid batt sys. Very intermittent, It will run for hundreds of miles then show the yellow triangle and hybrid sys warning. I clear pending code, all is well for a while. Today I used the paid dr. prius app and initially it said low values on 2 blocks , but next time it passed. Then i attempted to run the life expectancy test, I could only get the needle to stay in the green for around 1 minute before the test would not complete , seems like everything runs out of juice. any ideas ???? getting around 40 mpg.
    pack voltage - 231.3
    blade v. - 8.26v
    SOC- 67.46
    current- 7.08a
    max charge power- 16.75 HP
    Thanks Tom
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    battery needs replaced soon
    52,902
    welcome!
    might not be too late for reconditioning: prolong systems by hybrid automotive
  4. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Check out the lithium link in my profile.
    There you will find the only HV pack that is lighter than any HV pack on the market.
    The only HV pack to provide longer than normal operation of the HV system.
    From the mind of the Dr. Prius App we all use today to check our HV batteries.
