2010 Prius II 155k - what to watch for or unload now?
Discussion in 'Gen 3 Prius Main Forum' started by DC2010, May 4, 2025.
  1. bisco
    51,897
    yes, i think that is a decent gamble
  2. Danno5060
    Danno5060 Active Member
    386
    198
    Wyoming
    In my opinion, the best way to determine the state of the EGR system is to pull it out and clean it. That way you can determine how much carbon deposits were in the system, and how freely the valve was to operate. It sounds like it's overdue for that anyway. I'd also pull out the intake manifold and clean the passages there and replace the PCV valve while you're at it. That only adds a couple gaskets and a $10 PCV valve to the project.
    Since you live in the Rust Belt, maybe a better way is to see how badly the suspension is rotted out. Out here, I've gotten over 200K with the brakes on my old Gen 2, and they were still going strong.
    I don't know how much the tax code has changed, you may have missed out on it but I bought a used Gen 4 Prime and got $4K back on my taxes. That was before 45/47 got back in office though.
  3. Mendel Leisk
    41,406
    Yeah it's virtually one of the rites of gen 3 ownership, to DIY the EGR cleaning. It's involved for sure, but not over the top. In addition to the top two links in my signature, here's a rough workflow:
    Professional EGR Cleaning Resources | Page 9 | PriusChat
    Doing it yourself, the most it's really necessary to spend would be a new EGR valve, if the existing has a groove worn in the "ski jump". (inside a little inverted bucket inside the valve). Other than that, everything is cleanable. You're looking at around $30 for replacement gaskets on the intake manifold, just the pliable ones, the metal gaskets are much more durable. Plus rags, brake cleaner, caustic solutions for the EGR cooler.
    Don't get complacent, thinking a long overdue EGR cleaning will prevent head gasket failure. I'd be prepping for that eventuality as well.
    #23 Mendel Leisk, May 19, 2025
  4. Leadfoot J. McCoalroller
    8,076
    7,557
    Pennsylvania
    2018 Prius c
    I think it might be useful for you to understand that not everyone agrees that cleaning the EGR is that much of a necessity. Personally I look at it as an interesting theory, but I've never seen any real data to support it.
    It's a moot point to me because our car has a different engine with a different EGR system and isn't known to clog its cooler OR breach its head gaskets.
    There are other theories as to why a Prius with the 1.8L engine so easily breaches its head gaskets and most of those have nothing to do with EGR. They are more focused on the limitations of the cooling system leading to overheat, which has been a classic cause of failed head gaskets across essentially all gasoline engines for 100+ years. I tend to put more stock in them.
    The Prius has long been known for giving a "bathtub" graph for costs: Very expensive the day you buy it, then it plummets to little more than fuel and car washes, and then it rockets back up to the four (or five) figures at the end. Visualized, this is like the trough of a bathtub: |____|
    The span of years between the start and end of that graph is variable, but in salty areas the average is pretty close to 15 years. Plenty of people have squeezed many more miles out of their cars, but if you look closely you'll notice that most of them slammed those miles on in the first 12-15 years.
    I'll finish with the suggestion that you consider the cost trends of whatever your next car is going to be. You're in a good position to recover reasonable value* by trading or selling what you have now. If you let the car run to an expensive failure, there will be much less left to recover.
    Would you rather get a good trade now on a "merely expensive" newer car, or a terrible trade value on one that has had time to go up even further?
    *Ideally the best time to really get a strong trade is about year 14. This is because banks will write traditional used car loans on cars up to 15 years of age, so the dealers have a relatively easy time selling it for good money and can thus afford to pay the best trades. Once the car is 15 years old, it will most likely go to a buy-here-pay-here lot with alternative financing, the price ceiling will be a good bit lower and thus the potential trade amount is lower.
    Brian1954 and bettergolf like this.
  5. tonycd
    tonycd Member
    84
    56
    IMHO, yes, it's an excellent gamble. The prices of used cars today are not reasonable. You're almost always better off keeping what you've got than replacing it now, especially if you know it's not currently making any trouble. 5k oil changes seem to largely negate the ring wear issues on this engine, and the hybrid batteries have often achieved exceptionally long lives in grueling NYC taxicab duty. Our 2010 gets 5k oil changes, a brake service when it needed it at 105k, all the usual fluid changes, and is still merrily sailing on at 165,000 miles. Someone else's used car is a basket of unknowns they chose to sell to a stranger. I'm sitting tight right where you are, and I'd agree with you doing the same.
  6. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    I'm in the camp (now) of keep the car as long as reasonably possible and save your $$$$ so you can (easily) purchase a new car when needed. Decide the $$ amount you're willing to spend to keep the car running and what is your walk-away point. Say...$2K is the most you'll ever spend on this vehicle from this point forward. If your vehicle can last another 24 months, that's $$$ saved for the next vehicle.
    However, if you can't take that kind of risk and it's too much, then ... sell the car and get a new(er) vehicle.
    I have a 2010, purchased new, and I have under 40K miles. Yep you read that right. So I'm not buying anything now or yet... I hope my car will last another 5 years. Mileage-wise it shouldn't be a problem since mine is so low miles, but even though I'm in the southeast U.S. with no salted roads, age can still do it's thing I suppose.
