2010 Prius II HV Battery Reconditioning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raytheeagle, Jun 3, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I have the Intelligent Discharger, so no bulbs;).
    @WilDavis , @JC91006 or @jerrymildred might be able to offer tips with the bulbs(y)
    #21 Raytheeagle, Nov 26, 2017
  2. JC91006
    16,769
    8,567
    The bulb discharger takes a looong time to complete. I hope you'll be down to 134w by the time you go to bed tonight.
    You will also need a set of 25w bulbs for the lower voltages, you won't be able to go down under 134v with the 40w bulbs. I normally switch to 25w bulbs when I get to 180w.
    m.wynn and Raytheeagle like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Just follow the chart Jeff provides on his website. It's slow, but safe.
    WilDavis, m.wynn and Raytheeagle like this.
  4. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    I got it down to 86v today and am now in the charging process. It’s reading 221v as I type now. Each block voltage is around 15.6/15.7. Is it safe to leave plugged in overnight? It’s 37 degrees F here in Pittsburgh, so no heat worries. The fan is also running.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Leave it charging overnight ;).
    Sounds like a productive Sunday (y).
    jerrymildred likes this.
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Sounds like you have it nailed! If you check through past threads you'll learn why I eventually went with the IntelligentDischarger - the bulbs, although they work just as well, are a bit of a PIA to deal with (particularly the hot 200Watters at the beginning - although the heat problem can be alleviated by the use of the MajikExtenshunKord) - cool temps during charging are good for the TractionBattery! Tip: Long charges are good, I've found that some of the charges I've done can take up to ~30 hours! :eek:
    jerrymildred and Raytheeagle like this.
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Let the 2 cycle reconditioning process begin:):
    More updates to follow;).
    Happy Easter everyone (y).
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Top end balancing done, now onto 134 volt discharge:):
    FE9D244B-2C07-408E-8840-BCDE304E348B.jpeg 32A50718-57E0-45FD-821A-44FA1CE99E02.jpeg
    The process keep moving right along(y).
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    My timing was very good when I checked up on our 2010:
    Then when hooking the charger back up 1 minute later:
    1 discharge cycle down, 1 to go(y).
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Just finished the top end balance as the charge was holding steady at ~238 volts for several hours:):
    ECE24D0A-5699-4B89-9792-825FA13311C6.jpeg FBF91805-4D14-4A33-BC34-BE6DDCEB9B0B.jpeg
    Onwards to 84 volts;).
    Should be in about 5 hours (y).
    sorrywereclosed likes this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Just completed the second and last discharge cycle :):
    11A3875B-5BE4-49FE-AC52-BDBD2C88BC27.jpeg 055D53AF-DFF4-4DF6-8EEC-EA8309B0B775.jpeg
    Wasn’t as fortunate this round to catch the voltage as it was completing :(.
    But the process is still easy(y).
    Bay Stater and jerrymildred like this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Last top end balance completed:):
    It sat at 238-239 for 5 hours, so I’m calling it;).
    Whole process started at 9 PM Thursday and done 9:30 AM Sunday for a 2 cycle reconditioning:).
  13. Kuang
    Kuang Member
    37
    38
    US
    My car is 2010 Prius III, using Prolong grid charger. How do I know the balancing process has completed ? Thanks
    Raytheeagle likes this.
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The charger will display the voltage and when you see the voltage stable (within 1-2 volts for ~4-6 hours), you’re good:).
    Mind sharing a little bit about your situation:
    • How many miles on your Prius?
    • What led to getting a Prolong setup?
    • What area of the country you are in?
    Hope that helps and keep us posted (y).
  15. Kuang
    Kuang Member
    37
    38
    US
    Thank for quick replying,
    My Prius is about 240K miles.
    It is just preventive.
    I am in SoCal.
    After 15 hrs The Prolong's meter shows 236v and 332A. Is it good ?
    Thank again.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    It’s probably 0.332 amps or 332 mA;).
    Is this the first top end balance before you recondition?
    How many reconditioning cycles are you going to do?
    Have you been checking the voltage periodically?
    How long has it been at 236 volts?
    At 236 volts, it might be done, but I’d leave it on for a couple more hours:).
    Good luck and keep us posted (y).
  17. Kuang
    Kuang Member
    37
    38
    US
    Thank for correcting me.
    It's 332mA.
    This is first top and balance. I do not plan to do the recondition that take too much time and the battery is still healthy.
    It's at 236v for couple hours.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Not sure what ambient temps are there, but if the voltage has been stable, I’d call it good:).
    Ambient temps affect the top out voltage, so if somewhat warm, it will be slightly less;).
    Don’t forget once you take the charger off to let your Prius sit for a bit before taking it out(y).
    Chba, m.wynn and jerrymildred like this.
  19. jerrymildred
    11,517
    14,152
    Tampa, FL
    What @Raytheeagle said.
    I also agree that, since it seems healthy, topping it off is sufficient. Instructions say to let it sit at least a half hour before starting the car. I'd wait at least an hour. I've also thought about maybe next time hooking up the discharger for a few minutes and then letting it cool for a while after pulling the charge down a little.
  20. Kuang
    Kuang Member
    37
    38
    US
    This is update message:
    I did 4 times of charging to my battery in 5 weeks. And seeing : the more I charge the battery the smoother acceleration I have. Therefore I am wondering: how often can I charge HV battery ?
