2010 prius III, not Three, rattling noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, May 13, 2016.
  1. ATlam
    ATlam Member
    66
    57
    San jose
    once in awhile, as in maybe once a month or every few thousand miles, I hear a rattling noise in the rear below the car. It is very audible and everyone in the car notice it.
    This happen only when I have been in traffic for awhile during which:
    1) when battery is running really low from moving at low speed
    2) After which the engine is turned on to charge the battery
    3) moving low speed with the engine running.
    The vibrating noise increases as my speed increase, getting more audible and vibrating faster. After a certain point (maybe 30 mph) the noise stopped.
    This only happen once in awhile and ONLY during this circumstances when I'm stuck in traffic with low battery, low speed, and the engine is running. Anyone have any idea what could be causing this?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  3. Mendel Leisk
    42,349
    Check the exhaust and it's hangers. Maybe give it a shake.
  4. ATlam
    ATlam Member
    66
    57
    San jose
    I'll do that, thanks.
  5. Lemans_TS050
    Lemans_TS050 New Member
    Georgia
    I have 2010 and experiencing bad rattle sounds like a diesel/knocking sound when battery is low and engine is charging at 15-20% throttle. Similar to you. Did you find solution?
    #5 Lemans_TS050, Jul 26, 2016
    Tanderson82 likes this.
  6. Tanderson82
    Tanderson82 New Member
    Covington, LA
    Did you ever find out what was causing this issue? My Prius is doing the exact same thing.
  7. Inspector858
    Inspector858 New Member
    San Diego
    TSB emissions warranty for EGR. Aka knocking when motor kick on. This is a design flaw and they should recall this which ultimately leads to head gasket failure. This is notorious fir these cars and some for the Lexus with same motor ct200h.
