2010 Prius Intermittent Front Wiper Problem, works when pushed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shamrock2012, Jan 12, 2019.
  1. Shamrock2012
    Shamrock2012 New Member
    Massachussetts
    the wipers on my 2010 Prius starting having issues working only on the highest setting at random, sometimes stopping in the middle of the windshield. The wipers will operate if I physically push the wipers back and forth a few times, once they are running they seem to work until I cycle power or change the setting off and on.
    Seeing other user's post's, I checked the fuse and then replaced the wiper switch to see if that would help and it did not. The wipers only work intermittently on the highest setting of the switch.
    Any ideas? Anything I can try before getting a new motor? Is that what I even need?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds like a weak motor
  3. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    It's the switch contacts in the wiper transmission. Almost every car on the road does this the same way- the wiper power is routed through the stalk switch, and wired in parallel to a secondary switch inside the wiper transmission. That second switch is open when the wipers are at the full-down park position, and it closes when the wipers are in any other position. This way you get automatic wiper parking.
    The switch inside your wiper transmission has worn or broken. I haven't tried to repair a toyota wiper assembly, but generally speaking they aren't worth it. Much easier just to replace the assembly with a used one from a junkyard.
    It's an integrated assembly that includes the motor, usually looks like this:
    (general reference only; not a toyota part)
    In this example the transmission is the black plastic box in the middle, but the junkyard would almost certainly deal with it as a complete assembly as pictured.
    Robert Holt, Raytheeagle and JC91006 like this.
  4. Shamrock2012
    Massachussetts
    Thanks, the strength is very weak and I put new wiper blades that was relatively sticky and harder to push.
    If put the blades up removing all contact with the windshield, the wipers do move on all settings(if I’m not mistaken)
    Still look like I need new assembly with motor? I ordered a used one off eBay.
  5. Leadfoot J. McCoalroller
    8,271
    7,775
    Pennsylvania
    2018 Prius c
    They'll work when they're free up in the air because there is enough inertia in the assembly to re-close the internal parking switch. The delicate "make or break" balance is shifted towards "make." When the wipers are on the glass, there's too much drag. Sometimes you'll see a difference depending on whether the glass is wet or dry- the water lubricates the blades.
    Still needs the same fix.
  6. Shamrock2012
    Massachussetts
    Roger, waiting on used part to come in. Thanks!!
  7. robomoto
    robomoto Member
    78
    56
    Surrey, BC, Canada
    I had the exact same problem on my Prius. Wipers would intermittently stall in speeds 1 and 2, but will always work at speed 3. Opened up the wiper motor, and found out that the carbon brushes for the two slower speeds were worn down, and all the crud and debris inside was preventing a good connection. All it took was a through cleaning of the carbon deposits to restore function. Had me really panicking at first. If you ordered a used motor, it might also be dirty inside. You may still be able to recondition your old motor and reuse or sell it.
  8. Raj Nadar
    Raj Nadar Junior Member
    16
    Annandale, VA
    I have the same issue...took it to a mechanic and told him to clean the debris but he told me after inspecting it that there was no dirt/crud there and would replace the motor for me (over $100). He seems like an honest mechanic but I'd like to inspect it myself (if it is easy to do). Can you provide some detail as to how you went about doing this...hopefully I won't have to get the mechanic to replace it.
    Thanks.
  9. letsgobobby
    letsgobobby Junior Member
    32
    Am having basically the same problem. If I have to remove the wiper assembly then open the motor then brush and clean something I’m going to to take it to the shop and have them replace.
    Would it make sense to have them replace the spark plugs, as well, since I believe you have to remove the wiper assembly to replace the spark plugs? Those are due in 15k miles which is about 1 year of driving. We currently have 225k miles and we last replaced them at 120k, so they’re due at 240k.
    We hope to get about 2 more years out of the car which is about 30k miles for us.
  10. Joe Dahmen
    Joe Dahmen Junior Member
    East Vancouver
    Technology
    Same problem here on a 2010 Prius. Wipers work on fast mode, but not any other. Motor seems strong on fast mode. Worth taking apart the motor to see about crud /Dirty contacts in there? Or just replace the whole assembly?
