2010 prius Is lagging very badly when accelerating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Amazon flexer, Jun 3, 2018.
  1. Amazon flexer
    Amazon flexer Junior Member
    Stockton
    Hi guys,
    I just got my 2010 prius IV a few months ago. It got really hot today in the central valley (100f) and my car is very noticeably lagging when I press the accelerator (maybe 2 second lag) I dont know if this is just from the heat, or the weather is just coincidental. The car has a new fram air filter, and recently had the timing chain cover seal replaced by the dealership under warranty. I use my car to drive amazon flex maybe twice a week and I really need this problem solved. The car is showing no codes, has oil halfway in between low and full. Oh the car has 114k. Should I clean the maf? Change the pcv valve?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • Have you just began noticing the lag?
    • How many miles have you put on your Prius?
    • Do you hear the battery fan by the rear passenger seat at all?
    • Has the egr circuit been cleaned as well as the intake manifold?
    • Is the mpg declining and by how much from normal?
    Keep us posted (y).
  3. jack black
    jack black Active Member
    225
    142
    I
    Did the HV battery fan run in high speed all the time?
    Did the engine run all the time while stopped?
    Those are signs of overheated HV battery.
