2010 PRIUS IV - engine/transmission - headache/migraine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GearHead600, Feb 22, 2020.
  1. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Might be the solid/hydraulic lifters?
    GearHead600 likes this.
  2. GearHead600
    GearHead600 Member
    64
    74
    Chicago, IL
    Update: That one time on the road trip is the ONLY time it has done that weird startup shake thing! This is my Daily Driver, AND my work car (for those just tuning in, this car is my DD, AND for full time uber/lyft work)! Current mileage is almost 313,000 now (as of today)... Sadly I did have to drop the car at a body shop for some MINOR body repairs (I had a guy literally BACK into me at a drive through!)... So I should be without the car for 3/4 days or so while the shop repairs the front bumper/cover, headlight and whatever paint/paint matching they have to do! Thank god the guy admitted fault and everything, he is paying out of pocket, but who knew a little 1-2MPH "bump" could cause so much damage (cost wise) - the estimate was damn near $2,000! Oh well, glad I am not paying it! Also glad it wasn't a "real crash" seeing as I've heard Prii don't take well to being hit, and "are never the same again" afterward... I am thinking this very minor 1-2MPH parking lot "bump" doesn't count for that :eek: :s I hope!
    But anyway, my G/F's 2011 (DD and FT uber/lyft as well) Prius is now exhibiting symptoms of needing a damper! Guess hers is going in as soon as mine comes back from the body shop! Sheesh, if it ain't one thing it's another! Hers is a 2011 with 361,000 currently on the ODO...!
    As usual, will update this thread periodically!
  3. GearHead600
    GearHead600 Member
    64
    74
    Chicago, IL
    I'd have to look into it! It's only done it that one time, and that was somewhere around 21,000 miles back at this point...!
  4. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    Great article your posts are all clear, detailed and well written.
    In short hand I will say thank you x 50.
    I think I have your damper condition based upon your arguments that hard acceleration stopped the noise, highway driving stopped the noise and neutral stopped the noise. I have already done the EGR system and plugs and I have no coolant leak. I must find a good garage in the Montreal area to first confirm my head gasket is good and that they are able to do the job. Hopefully the labor will be close to what you paid.
  5. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    Nope though my symptoms were identical to yours -- based on your descriptions -- my problem turned out to be nothing more than a loose middle heat shield. I guess I was lucky. As well, I have become pretty knowledgeable on the damper replacement if I ever need to do it.
  6. Pollymath
    Pollymath Member
    102
    37
    Flagstaff, AZ
    These symptoms sound almost exactly like what my 2010 does.
    I've had a lot of issues with clogged EGR, clogged catalytic converters, bad plugs, even a case where my catch can unscrewed itself, but now, after finally being "code free" I still get this weird "clatter" sometimes when I stop, and this odd "surging" sometimes when I let off the throttle.
    Lucky for me however, my decision is easy - because my car burns approximately a quart of oil every tank, I'm not going to bother with the damper replacement, but at least I have some idea what is causing it.
    I'll probably still clean my throttle body and traction battery fan vent, but I doubt those will make any difference.
    On the upside, the new plugs have greatly improved gas mileage. Gonna hit my first 480 mile tank!
