2010 Prius IV mystery button
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ralph Spoilsport, Mar 12, 2016.
  1. Ralph Spoilsport
    Ralph Spoilsport Junior Member
    Palm Desert CA
    Hi everyone, I'm back after a long absence. Just got rid of my 2014 Prius C and acquired a beautiful blue 2010 Prius IV. Seems to be running great, a few odd sounds, but I love it.
    It came with a few mysteries (I bought it from a proxy, not from the actual owner/driver):
    Below and to the left of the steering wheel, where the mirror controls, the solar fan switch, and the interior light level adjustment live, there is an on/off switch. It's an aftermarket thing -- the folks at my local Toyota dealership could not figure out what it does. I can't figure out what it does. Any guesses?
    (I can't seem to figure out how to post a photo.)
    Thanks everyone! More questions later probably!
    Ralph Spoilsport.
    Prius mystery button.jpg Here's a photo
    #1 Ralph Spoilsport, Mar 12, 2016
  2. Tideland Prius
    16,670
    Congrats!
    Well it's where I installed my foglight switch when I added foglights (only the V/Five had foglights). Perhaps that's what it is? (or maybe it's a PCer's former car lol)
    sprtent likes this.
  3. 48mpg
    48mpg Member
    193
    47
    florida
    I
    what ever you do dont press that button..bad things can happen when you press random buttons...could start WW3 :confused:
  4. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Turn it on and see what happens!
  5. Ralph Spoilsport
    Palm Desert CA
    Hi Tideland, thanks very much. I think it might be for the foglights -- because there are foglights on the front of my car, but I do not have the foglight on/off controls on the headlight-control steering wheel stem.
    The reason it's a mystery, I guess, is they don't work. When I toggle that on/off switch, nothing happens. I suppose I'll see if I can find someone to take a look. But since I live in a place where there's never fog, maybe I don't really care.
    Thanks so much!
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Turn it on, then see if you wind up in a funny little town that has no other people.......and then the voice of Rod Serling starts to chime in.......
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Try the "foglight" switch again, with the main lights in varying positions. Sometimes, they are wired to not work when main headlights are ON, and only work when main switch is in the parking light position. Your car should also be in the READY mode. Failing that, you could check the fusebox for where they might have tapped in that switch and check fuses. Maybe the previous owner is just messin' with you by putting a dummy switch in the panel! Maybe a mod he started but didn't finish.
  8. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    Navigation override maybe? So you can change settings or enter nav destinations with the vehicle moving?
  9. Tideland Prius
    16,670
    :D
    Depending on how they're wired, you need the parking lights or the low beam headlights to be on before the foglights will come on. They will not turn on on their own.
    48mpg likes this.
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The daytime running lights on my Prius won't come on if the parking brake is engaged. Because... who knows?
