2010 prius loss of communication. Codes u133, u129, and u155.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Julia Godel, Jul 21, 2019.
  1. Julia Godel
    Julia Godel New Member
    Meadow Grove, ne
    2010 prius loss of communication. Codes u133, u129, and u155. Happened suddenly while driving. Mechanic can't find the issue. Car will start, but will shut off once put into gear. Any suggestions?
  2. PriusCamper
    PriusCamper Senior Member
    12,018
    4,882
    Pacific Northwest, USA
    I think these are subcodes... Is there a code that points to what these codes are associated with? Also how many miles on car and any other symptoms prior to it not working after shifting into drive?
  3. ChapmanF
    17,271
    Communication DTCs generally do start with U, but they should be five characters, not four. Is it possible these weren't quite transcribed right?
    PriusCamper likes this.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I think the leading 0 was just left off.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Just for the sake of argument, hook a jump box, or cables to the jump point under the hood and see if the car will go into gear/stay in ready. If it does, you jsut need a 12v battery.
  6. PriusCamper
    12,018
    4,882
    Even if you add a zero or letter O at the start of those error codes, there's still no trace of them ever being mentioned on PriusChat or elsewhere. Without the mechanic explaining why they claim nonsensical error codes that they can't fix, there's no way we can help other than telling original poster to go to a real mechanic.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Yes there was a mention of “Multiple Loss of Communication errors” on a November 2018 thread. I think the lack of any other codes besides those three says to test or replace 12v and see what happens.
  8. Mendel Leisk
    40,553
  9. ChapmanF
    17,271
    We should fix that. I'll mention the U codes that are covered in the 2010 Repair Manual:
    U0073, U0100, U0101, U0104, U0110, U0122, U0123, U0124, U0126, U0129, U0131, U0140, U0142, U0146, U0151, U0155, U0164, U0235, U0293, U029A, U0327, U0424, U1000, U1002, U1100, U1104, U1105, U1107, U110B, U1119, U1133.
    That way they should come up in a search, and folks'll know where to get more information.
    The only one from this post that I don't see is U0133, so I wonder if that one got transcribed funny.
    U0129 is loss of communication with the brake ECU, and U0155 is loss of communication with the combination meter.
    Edit: U1133 (in case that's what the funny one really was) is loss of communication with the "PMN module". Your guess.... I think it might be the "park" switch.
    #9 ChapmanF, Jul 22, 2019
  10. waldox
    waldox Junior Member
    69
    toronto
    pmn may be the power control module/power management n....?
    i get a related code b278c which is about the power management module and smart key module
    #10 waldox, Apr 24, 2022
  11. ChapmanF
    17,271
    You could be on to something ... that's the column the ○ appears in, in the CAN No. 1 Bus DTC combination table.
