2010 Prius Lumbar Support part numbers?
Discussion in 'Gen 3 Prius Main Forum' started by Adam Alvarez, Mar 14, 2020.
  1. Adam Alvarez
    Adam Alvarez New Member
    Fallbrook, CA
    Hello all- I recently picked up a 2010 Prius and have no complaints except that the lumbar support wasn't functioning as expected, so I took it apart and the plastic gear in the wire pulley system decided to fall apart.
    Anyone know what the part number is for the entire lumbar support assembly? or the Motor with Pulley, or just the Pulley? I found a pic of the assembly and circled the problem part.... The motors working everything else is in tact. Just no way to adjust the lumbar outside of opening the seat and messing with it manually.
    Thanks!
  2. frodoz737
    frodoz737 Top Wrench
    4,809
    2,562
    33
    Call the Dealership Parts Dept. with VIN and description. They will give you the info in minutes.
    Grit likes this.
