2010 Prius maintenance schedule
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrDan, May 23, 2025.
  1. MrDan
    MrDan Junior Member
    38
    Pomona
    Does any one have the Toyota original maintenance schedule PDF link for 2010 Prius ? I can't find it anywhere. I've seen some made ones on here but I just want to see the real one. Having some dim headlights and radio flickering issues might be my inverter or 12v battery. Also might change my inverter coolant
    Thanks
  2. BiomedO1
    BiomedO1 Senior Member
    4,511
    2,366
    Left Coast
    Clean out the car and remove the covers to access the 12V battery. Take the car to any auto parts store that'll do a free battery check.
    Have you had your headlamp lens repolished? Those plastic lens get road pitted and foggy, preventing/reducing the light from projecting through the lens. You may also have loose wiring and/or bad ground cables or rodents chewing on your wiring harness.
    Good Luck....
    https://assets.sia.toyota.com/publications/en/omms-s/T-MMS-10Prius/pdf/2010_Prius_WMG_0W20_lr.pdf
