2010 Prius makes ticking noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mbrubaker, Jul 22, 2020.
  1. mbrubaker
    mbrubaker Junior Member
    Our 2010 Prius level 2 has started making a very faint ticking noise when I have my foot on the brake pedal at a stop sign or stop light. Think of the 60 Minutes TV show clock ticking only very faintly. When I take my foot off the brake the noise stops, starts again if I put my foot back on the brake. Had the brake system looked at by a non-Toyota tech, who found no obvious problem. Has anyone else experienced this or have an idea of what the cause of the noise might be?
    AzusaPrius likes this.
  2. RRxing
    RRxing Senior Member
    2,561
    1,837
    NEPA
    I hear the same thing on my 2017 when slowing down to stop. Since its always done it, I'm assuming (yeah, I know) it's normal. The tick-tick-tick frequency corresponds to wheel speed and is only audible at slow speeds. Anyone know better?
  3. SB6
    SB6 Member
    324
    71
    @mbrubaker the ticking only occurs while you're stopped and the brake pedal is depressed? Maybe something to do with the brake booster or the brake pedal?
    If your ticking is while you're at (low) speed, maybe the rotor or something is hitting the dust shield (the little metal plate that sits behind the rotor)? Or maybe dirt stuck on the pads or the rotor?
  4. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Are you up-to-date with the recalls on your car? One recall in 2010 (not all 2010s) was the brake booster pump.
    Maybe you can localize the sound better if you have someone apply the brakes while you listen under the hood, if the sound occurs while in Park; also check if you hear it while in Reverse and Neutral. You could also try to hear it with the heat on, versus off, and with the car cool, versus warmed-up, to eliminate the engine water pump as a culprit.
    How many miles are on your car?
  5. RRxing
    2,561
    1,837
    NEPA
    Q#1 - Possible. I'll have to check it out, but not today, too damn hot...
    Q#2 - Doesn't sound like it would be this.
    Thanks for the reply...
  6. AzusaPrius
    AzusaPrius Senior Member
    2,249
    940
    I believe my car has the same "ticking" I think it sounds like a dinosaur raptor and happens exactly how you explain it.
  7. orenji
    orenji Senior Member
    5,887
    3,488
    It's very common and no one has really determined what the cause is. Some dealers suggest replacing the axel. But after awhile it comes back. I would not worry about it.
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Since we're guessing, I'll put in my thought. I suspect a catalytic converter cooling and producing the tink-tink sound which would normally be inaudible but for the fact the ICE isn't running. I don't think it's a brake booster sound, but it's odd that it goes away upon lifting foot from brake. Did the 2010 have the hill-hold feature? That would illuminate one of the dash idiot lights when activated.
  9. RRxing
    2,561
    1,837
    NEPA
    I should add that this only occurs at slow speeds when the brake is applied.
  10. mbrubaker
    1. As near as I can tell, the ticking only occurs when the brake pedal is depressed at a full stop and wait. The sound is so faint that I don't think I could hear it over road noise if it occurred then. I have experienced no problems with braking.
    2. No error codes have shown.
    3. If this is a common problem can anyone supply links to more info about it?
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Yay this topic again!!! This gets posted every quarter, just like installing 86 wheels. Every turd gen has this, get it replaced w/new parts and it will return. Listen to other turd gens slow down next to you at a stopped intersection with your windows down, it doesn’t discriminate.
  12. RRxing
    2,561
    1,837
    NEPA
    Uh, I have a Gen IV...
  13. SB6
    SB6 Member
    324
    71
    This is the Gen 3 forum
    Grit likes this.
  14. RRxing
    2,561
    1,837
    NEPA
    But it seems like the ticking occurs across generations, so it could be a common issue.
    SB6 likes this.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Sources please.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Rules are just a suggestion :ROFLMAO:
    AzWxGuy likes this.
  17. SB6
    SB6 Member
    324
    71
  18. RRxing
    2,561
    1,837
    NEPA
    Posts 1-14...
  19. RRxing
    2,561
    1,837
    NEPA
    EXCITING UPDATE!!! :rolleyes:
    I rotated my tires today and now the tick-tick-tick is GONE!
    Still can't say what caused it, though... :(
  20. orenji
    5,887
    3,488
    Lug nuts needing to be tightened maybe?
