2010 Prius malfunction
Discussion in 'Gen 3 Prius Main Forum' started by Belal Abdallah, Sep 3, 2018.
Tags:
  1. Belal Abdallah
    Belal Abdallah New Member
    Corona ca
    Hello y’all, just wanted to see if I can get some advice for my Prius.
    So recently I had a fire near my home. It got to the point it was really hot.
    1- my vehicle doesn’t charge as quick anymore. When I have the AC on. My battery stays at 2 bars or 3 Max. How can I tell if my batteries have gone bad ?
    2- i was driving and this happens before the fire. My vehicle just went crazy. I got the hybrid system failure light. And my vehicle went into safe mode and I was only able to drive it for about 1mile before it shut down. I took it in and they said I needed gas. It’s kinda odd that I needed gas when I had a few bars left. Once they put the gas my lights went away. Had this happened to anyone else ? I feel like I got played at the dealer. I paid for a multi point inspection so they can check my batteries but never received that service. I’m taking it back or in contact with the supervisor to help assist with it. I checked my vin against recalls nothin popped up.
    3- when I press on my gas pedal I have about a 3 second lag. Until the car catches itself and it moves. Anyone know why ? Happens to me all the time.
    4- excessive oil consumption. Read a forum of a bad piston ring. I guess I’m not the only one.
    5- AC when it’s on and running. The vehicle works twice as hard and doesn’t charge. Or won’t charge fully. Anyone know if this is normal ? Max charge will get to 3 bars.
    Last is there any way to find out if I have a bad battery or a bad charger or a bad transmission. I feel all these things happening. Fall under a few subjects. Battery charger, converter, faulty batteries, or bad fuel injectors response. Thank you all for your help.
    52,847
    welcome!
    you will need the trouble codes. is the inverter pump working?
    have you cleaned the egr?
    how many miles on her?
