2010 Prius marker light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sunseeker, Mar 18, 2023.
  1. Sunseeker
    Sunseeker Junior Member
    During service and inspection, dealer noted that both upper marker lights and driver side lower marker light were out. I replaced the upper marker light bulbs but what the heck is a lower marker light on 2010 Prius. All I see on the lower side is the turn signal, and they're both working.
  2. Tideland Prius
    16,665
    There are two marker lights. There’s the forward facing one above the high beam and the “usual” one behind the low beam, behind the yellow reflector.
  3. Tombukt2
    Tombukt2 Senior Member
    13,798
    2,501
    Durham NC
    Put 194 ZEVO 1 watt in they're . Never touch again. Or whatever you have on yours
