2010 Prius- Master Warning light and slip indicator light on when starting the car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cdnmary, Jan 13, 2019.
  1. Cdnmary
    Cdnmary New Member
    Ontario Canada
    My 2010 Prius master indicator light and slip indicator light comes on when I start my car and then goes away. What does this mean? Am I pressing too hard on my brake?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    It is normal to see all the warning lights for 2 seconds when you start the car. This lets you know the lights are working properly. You should worry if you don't see them.
  4. Mendel Leisk
    38,253
    Maybe.
    @Cdnmary are these light's "lingering", say 10~15 seconds, or is it just a split-second while the car is booting up?
  5. Cdnmary
    Cdnmary New Member
    Ontario Canada
    Thank you everyone. I just found a you tube video that also explains it is a normal function that somehow I never noticed.
  6. hamlin
    hamlin New Member
    Louisville
    I HAVE HAD A SMILAR ISSUE WITH MY 2012 PRIUS. SLIP INDICATOR LIGHT USUALLY GOES OFF IN A COUPLE OF SECONDS BUT DOES IN FACT SOMETIMES "LINGER FOR 10 TO 15 SECONDS". IT DOES ALWAYS GO OFF HOWEVER. ANYONE OUT THERE HAVE AN OPINION ON THIS? AND WOULD PRESSING THE BRAKE PEDAL MORE LIGHTLY BE BENEFICIAL? FINALLY CAN YOU POST THE TITLE OF THAT YOU TUBE VIDEO OR PROVIDE THE ACTUAL URL LINK? MANY THANKS.
