2010 prius misfiring
Discussion in 'Gen 3 Prius Technical Discussion' started by FoxHound, Mar 10, 2019.
  1. FoxHound
    FoxHound Junior Member
    Madison Wi
    The engone shakes like its trying to tear itself apart. Dadh tells me it is currebtky getting 22mpg.
    I get codes telling me that thwre is a miss fire in cylinder 1 and 2 and sometimes 4.
    I have replaced all 4 cops. When that didnt work i swapped around the coils yo see if one of the new ones was bad.
    When that didbt work i replaced the spark plugs.
    When that didnt work i cleaned the injectors and mass air flow. When that didnt work i vhecked the resistance of the 4 fuel injectors and they came in between 11.1. And 11.6. I havent beem able to find the ideal resistance listed foe these fuel injectors.
    I also cant find the i formation needed to check the mass air flow sensor.
    Anybody have any ideas on what else could be wrong?
  2. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Try a search on "Misfire" for more information. Unfortunately a common problem with many generation 3 motors.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    How many miles on the Prius?
    Has the egr circuit ever been cleansed?
    What about an oil catch can?
    Good luck and keep us posted (y).
    SFO likes this.
  4. FoxHound
    Madison Wi
    Over 250k.
    I wull be cleaning the egr pupe tomorrow.
    I have no idea about an oil catch can
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    If the car is in Madison, you could always use @ericbecky as a resource :).
  6. FoxHound
    Madison Wi
    Deforest actually.
  7. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    That’s not that far away;).
    Close enough for a consult if nothing else(y).
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Sounds like you have a good handle on things.
    Methodically going through things.
    Not doing more than one change/test at a time.
    That's pretty high miles so it was probably good to replace some of those parts anyway.
