2010 Prius Models and Option Packages
Discussion in 'Gen 3 Prius Main Forum' started by Prius Team, Feb 10, 2009.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yup, to not engineer a car like the Prius so new tech like solar can't be bundled with a loaded model is upsetting... But let's not go down this road again, it's been stated many times but we have to live with it. Unfortunately, Toyota will take our comments and try to engineer te car so future models may have all 3 packages available together but that doesn't help those of us who will be buying the car now... I am sure knowing the US laws they could have somehow made it possible to bundle them all together but oh well, it wasn't meant to be I guess...
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Welcome Drs543, I made myself feel better by convincing myself how expensive it would be to have to replace any abnormalites of this new technology that warranty would not cover.
    They gave us a big enough hassle about the HIDs that I suppose I can live without them... and we never came to a conclusion as to how bright they are.
    I'm noticing LED's on the road now.. and I'm not impressed with many... I don't know how these rate against those yet.
    Although they are cool and the latest and greatest, I'm not sure if they have the bottom line brightness that the Halogens may have.
    I guess sometimes you have to look at the bright side of things.. "a little pun"..... thats what I'm trying to do..
    but I think I may have chosen them if I had the opportunity.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    drs - trust me, we all made a bit of noise about the LED and Solar mismatch. The LED's aren't just a direct swap as equipped either - there's a leveling sensor attached to the rear suspension and likely some additional ECU tie-ins surrounding that. LED headlight equipped vehicles also get headlight washers.
  4. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    Am I reading this right in that you have to choose one of the options packages which means you have to get a navigational package?
  5. rcsting
    rcsting Toyota Fanatic
    282
    112
    Gold River , California
    You can choose the base model (1223) which doesn't have the navigation package. Looking at the remaining models I'm not 100% sure if you can order the 1225, 1227, or 1229 without any option package.
  6. PriusCrazy
    213
    28
    Triad, NC
    Thanks for the reply rcsting. That got me to thinking and I looked over the details again and Doug stated that:
    "There are 10 possible ways to configure a 2010 Prius (excluding colors)"
    Just typing it out long-hand, while we wait for delivery... :)
    That would be:
    1. 1223 (no options)
    2. 1225 (no options)
    3. 1227 (no options)
    4. 1229 (no options)
    5. 1225 (Navigation package)
    6. 1225 (Solar package)
    7. 1227 (Navigation package)
    8. 1227 (Solar package)
    9. 1229 (Navigation package)
    10. 1229 (Advanced Technology package)
    Did I get that right?
  7. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    I did notice that a couple months ago and meant to comment.
    Headlight washers? You've got to be kidding me, Toyota. Can someone please explain that one to me?
    This isn't an off-road SUV that will get gobs of mud splashed all over. And if icing over is a concern, I would think an embedded defrosting wire would be more effective and last longer (no moving parts or cracking rubber blades to worry about).
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    It's an ECE requirement for any high-output lighting system. Wikipedia:
    "Dirt buildup on headlamp lenses increases glare to other road users, even at levels too low to reduce seeing performance significantly for the driver. Therefore, headlamp lens cleaners are required by ECE Regulation 48 on vehicles equipped with low-beam headlamps using light sources that have a reference luminous flux of 2,000 lumens or more. This includes all HID headlamps and some high-power halogen units. Some cars have lens cleaners fitted as standard or available as optional equipment even where the headlamp specifications and/or prevailing technical regulations do not require them. North America, for example, does not use ECE regulations, and FMVSS 108 does not require lens cleaners on any headlamps, though they are permitted. Lens cleaning systems come in two main varieties: a small motor-driven wiper blade or brush conceptually similar to those used on the windshield of the car, or a fixed or pop-up high-pressure sprayer which cleans the lenses with a spray of windshield washer fluid."
    The Prius is very nearly a world-standard car - the exact same model is sold all over the world with very minor modifications for the North America lighting requirements (different marker lamps are needed, and the door-mirror indicator repeaters on the EU and JDM models are not permitted).
  9. carz89
    444
    47
    San Diego
    Interesting...I learned something. However, as an engineer, I'm scratching my head as to HOW dirt buildup can INCREASE glare. But, I'll assume there's a good answer for that one.
    But ... the headlamp cleaning system is still at the whim of the driver (I doubt it is automatic). So, how effective are regulations to have specific equipment that could go unused so easily?
    I guess I'm a skeptic in need of a live demonstration.:confused:
  10. fuzzy1
    10,706
    In winter, I very regularly find that grime buildup on the headlights scrambles the careful beam shaping of the reflector and lens, scattering the light all over the place.
    A clean (and properly aimed) lens focuses most of the light in a low even pattern on the road, below the eyes of oncoming drivers. When scattered by a dirty lens, more light is fired high into the face of other drivers, and into the sky, and less lands on the road where I need it. In some weather, typically when the DOT has had to do a lot of sanding, my light becomes so dim (to me) that I have to pull over to clean the lenses. Very few other drivers ever do this.
    The grime on the windshield, outside the wiper pattern, is a strong indicator to the grime on the headlights.
  11. windstrings
    6,280
    378
    Central Texas
    Not to mention, wiring harness harness/computer feedback issues.
  12. Tideland Prius
    16,680
    Given that you're from San Diego, I guess you forgot about the white stuff we have to deal with in some parts of the country :p. In the winter, sand and snow come together to create what I'd like to call a mocha frap :D. All of that gets sprayed up to the car by your friendly SUV/pickup driver without mudguards/mud flaps. If the headlights are covered in grime, your light output is significantly reduced.
    Headlight washers help clean the lights while in motion so we don't have to stop at every gas station to wipe them clean.
    If I had to guess, the dirt scatters the light so some may scatter up and thus creating glare. It has a separate button in the Prius (thank god) and it's up to the driver to clean it. (I prefer this setup than those tied to the windshield washer system). There are some semi-automatic ones like the one on the new C-Class that sprays the headlight washers every 10th spray of the windshield washer fluid.
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Initially.....key word....the Prius team had to makes some decisions in order to tell the plant what to build and how many of what to order. This had to be done last year and finalized over the last month or two. I was a direct supplier to the D3 for a long time and we had roughly a 6-month leadtime before the vehicle left the plant. We needed to know at least 6 months before shipment how much and what was going to be used.
    This site and this thread are a good way to voice preferences. Obviously it's being monitored. But back to initially. Nothing is written in stone. To sell vehicles Toyota will adjust then readjust then rereadjust the packages and option combinations to fit the greatests number of buyers. The majority always wins. But the key point is that the packages have to reflect demand in order to sell the most units. After the initial arrivals if the current structure is moving well it will likely remain in place. If a demand is seen for Navi but no SRP like this year's package #6 then that'll be changed soon.
    This was done with the current 4Runner back when it first debuted. Toyota made an oops based on an erroneous view that the US public wanted dark gray unpainted overfenders like the Jeeps. The US buyers hated the look and made it known. After 90 days of low sales and complaints every 4runner since then has had painted overfenders. It took nearly 9 months to move the initial 90 day supply of unpainted overfender 4Runners.
    For certain next year the packages will change, then they will change again the following year.
  14. mirak
    mirak New Member
    127
    Hey Toyota - we all want a model V, no packages. Got it?
  15. Tideland Prius
    16,680
    ??? Isn't that a rather rude tone?
    Just order a Prius V with no package lol.
  16. bwilson4web
    16,533
    This had left me wondering if I wanted to be a 2010 pioneer or not because I don't care for some of the upscale product mix.
    Having been to the Georgetown KY plant three times, I remain amazed that Toyota lacks a web site that would allow me to custom order exactly the vehicle I want. I would be happy to take the listing to a local dealer with say non-refundable, 10-20% down; and wait 6-9 months later for the delivery and final payment.
    In the end, I decided the bottom kit would work just fine as the parts I'm most interested in, the engine and drive train and basic controls are there.
  17. PriusCrazy
    213
    28
    Triad, NC
    I have to agree with Tideland Prius, that did seem a bit coarse. I'm assuming it was done in jest.
    And by the way, we all don't want the model V, no packages. I want the model IV no packages. :D
  18. patsparks
    10,664
    569
    Adelaide South Australia
    10 different packages and everyone is crying? move to Australia where we will have 2 options, base and iTech. It gets a little tired after a while.
    If the 2010 Prius was perfect what would people have to complain about?
    Keep it up Toyota, the Prius has it all, a great car with stuff to whine about!
  19. PriusCrazy
    213
    28
    Triad, NC
    Nah, we're not whining. Just over-stimulated Prius fanatics anxiously awaiting pricing/availability details. :)
  20. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You may have two there but at least your second choice has what many here would have taken... Loaded WITH the solar moonroof and LED's minus the 17's.
