2010 Prius - More pictures and preliminary product information
Discussion in 'Gen 3 Prius Main Forum' started by Paradox, Mar 2, 2009.
  1. XxDarkSidexX
    XxDarkSidexX New Member
    Orange County
    you can always sell brand new leather seats and get whatever seats you wanted
  2. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    Sounds like a lot of work and a lot of pain for a 32k car.
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    You're right. I thought that sounded small, but didn't think to question it. Maybe we're supposed to double those numbers to get the true turning circle. 34.2 and 36? Hope Toyota appreciates all this fine proofreading we're doing for them! ;)
  4. Tideland Prius
    16,559
    Did anyone notice the est. city/hwy rating? it's pretty much equal across the board at 50/49 combined: 50.
    Or that the rear discs are larger than the front??
    Or that the height hasn't changed with the larger 17" alloys? (which means they lowered the car by an inch)
    Water repellent front windows is another Lexus feature (how many are there on this Prius?!?!?). As spwolf said, it's aids in visibility (i.e. checking your mirrors) as the water droplets glide more easily across the surface of the window, thus leaving the window with less droplets and thus a clearer view.
    The "step lamp" is what I believe to be illuminated door scuff plates... i.e. the illuminated PRIUS and HSD logos on the front door sill. The blue car at Detroit had amber/orange front footwell lighting.
    As usbseawolf said, it's the width of the tyre.
    Also our current Prius has HSEA glass and it's much better than the one found on our 02 Camry. I found the interior to be cooler even with the black dashboard.
    Niice. How is it that the cargo vol. is now 21.6 cu. ft? That's a huge jump from the revised 14 cu ft (or even the original 16 cu ft) of the current Prius.
  5. fuzzy1
    10,454
    A quick calculation suggests that the 17" wheels & tires should lower the car by 0.18 inch, compared to the 15", unless Toyota raised the car.
    I didn't check the tire manufacturer's website for rolling radius.
  6. Tideland Prius
    16,559
    oh??
  7. fuzzy1
    10,454
    Sidewall heights are different.
    P195/65R15: Radius = (195mm*0.65/25.4mm/inch) + 15/2 = 12.49 inches.
    P215/45R16: Radius = (215mm*0.45/25.4mm/inch) + 17/2 = 12.31 inches.
    I.e. the "little" wheel has a slightly taller tire. But this is close enough that rolling radius is needed, so see how much its gets flattened under load.
  8. Tideland Prius
    16,559
    Crap, I forgot about the sidewall heights! lol.
  9. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    Sorry for the confusion. The step lamp refers to the under console light in the front foot wells. The Prius/HSD illuminated scuff plates are an accessory that we are testing... and may bring to market.
    Doug Coleman
    Prius Product Manager
    Toyota Motor Sales, USA
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Aww shucks, I really liked the illuminated Prius scuff plate. Hopefully it's reasonably priced.
  11. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Could this simply be the radius of the turning circle? (Making the circle 36'.)
  12. mr.whit
    mr.whit Member
    117
    Michigan
    I love the looks of the new Prius and also have one on order, but I not sure about this picture that shows fog lights and a moon roof?
    Curb Weight: 3,042 lbs
    EPA Passenger Volume: 93.7 cu. ft.
    EPA Cargo Volume: 21.6 cu. ft.[/QUOTE]
  13. Tideland Prius
    16,559
    Ohh, then why not call it front footwell lighting like you do on the RAV4?
    Do bring the illuminated scuff plates. I almost bought a set for the current one but $260ish was a little pricey (maybe because it had to be imported from Japan?)
    +1
    [/quote]
    It's a grey cover. No fogs.
  14. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    +2 for the illuminated scuff plates :)
    I was nervous that they would only be available to those who get the solar panel moonroof option after only seeing it on the blue car... But this is something that I am sure if the price isn't absurdly high, many would spend for...
    Oh, and how about just making it part of the advanced tech package Doug? ;)
  15. mr.whit
    mr.whit Member
    117
    Michigan
    I think lighting should not be in only one package... give it up the LED lights, scuff plate lights and FOG lights. HEY how about a lighting package?
  16. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    The Toyota spec sheet says: "Turning Circle Diameter (curb to curb)" but you're probably right. Which is almost a deal-breaker for us. We love the nimbleness of our 2002's.
  17. a priori
    3,083
    408
    23
    Chicagoland (West)
    Even so, if the full diameter is just over 34', that is still pretty tight. It is better than a Mini Cooper, which is just more than 35'.
  18. Tideland Prius
    16,559
    True but the classic Prius had a ridiculously tiny turning circle. The current Prius had a normal compact car turning circle.
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    My 1972 Jeep C-J5 had a turning radius of 16.5 feet, which is a diameter of 33 feet - a very tight turning radius. Keep in mind that the wheelbase of that Jeep was a foot shorter than the classic VW bug.
    Tom
  20. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    I'm sorry if this is already covered elsewhere but I wanted those interested in the 2010 Prius to be aware that Road and Track announced in their April issue that on March 25, 2009 at 12:01 am EST ("hybrid history") they will post their "Exclusive Video" of their "...first driving impressions of the 2010 Toyota Prius..."
    RoadandTrack.com/Prius :rockon:
