2010 Prius MPG in cold weather?
Discussion in 'Gen 3 Prius Fuel Economy' started by nmeurett, Dec 5, 2011.
  1. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    fyp.
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    That may be the offical US Government calculations. But 3-5 mpg is the real world loss....
    al
  3. pederson80
    pederson80 New Member
    Cambridge, Wi
    deleted for error
  4. pederson80
    Cambridge, Wi
    I asked how much and they said $100 for labor not including the block heater. Most other body shops said between $70 and $100 for labor. Which is why I chose to do it myself but, it would be worth it for the short trips I think. I plugged in outside when it was just above freezing and my car switched to stealth mode in less than 5 minutes. Do you have any mechanically inclined friends? I could try to find the priuschat link with the all the info and pics on how to install it or you could do a search on the forums.
  5. pederson80
    Cambridge, Wi
  6. Joyce
    Joyce Junior Member
    40
    South of Boston
  7. deltanh
    deltanh Junior Member
    44
    Manchester NH
    I too had the same concerns. Got mine in August and enjoyed 61 mpg on the Cape. I noticed the mpg nosedive when the cold temps moved in. My commute is maybe 10 miles. I have since blocked off the lower grill as suggested on this forum and it does make a bit of a difference. I should add that I have steel wheels with Blizzak snow tires and use a remote start to defrost the windshield some mornings. My mpg is about 45. All things being equal, it is still at least twice as much as the 2009 Civic I traded in. Enjoy your new Prius.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    3% is the completely unofficial galactic physics number. The nasty US gubmint is sucking up to forenners.
  9. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Thats normal to a bit low, but winter warm up time takes a real bite out of average mpg.
    My 2010 Prius in North Dakota makes low to mid 50's in warm weather and mid to high 40's in winter depending how much I allow the car to warm before driving off.
    I am surprised to hear some with a gen 3 Prius are seeing lower MPG with E10.
    In very careful tests using fuel from my local station's blender pump, I compared MPG using several tanks each of 87 octane gasoline, 90 octane E10, and 91 octane premium gasoline. E10 did the best by 2 MPG.
    The problem may be that some stations use a low quality gasoline stock and add Ethanol until it meets the minimum 87 octane.
    The company I buy from uses their good quality 87 octane gasoline and blend in 10% ethenol to make their 90 octane E10. I try to fuel up at that company whenever possible.
    In winter I notice it takes 10+ miles until the car warms up and rolls free enough so near 50 mpg comes back.
  10. fuzzy1
    10,722
    fmr:
